× NETGEAR will be terminating ReadyCLOUD service by July 1st, 2023. For more details click here.
Orbi WiFi 7 RBE973
Reply
how to configure iStat on OS6?
ScottChapman
Apprentice
I got iSTat installed and running. But launch button is not active.
It does day what port to use, and what the default password, question is, what is the URL?
I tried http://<NAS>:5109 but get a "null" back.
Message 1 of 16
doylmi
Guide
Re: how to configure iStat on OS6?
Hi Scott - iStat requires a separate client application. There is no "URL", as it does not have a web interface.
For example, if you have an iPhone, you can purchase a client from Bjango:
https://itunes.apple.com/us/app/istat-2 ... 29458?mt=8
Alternatively, if you have an Android phone, you can leverage my application, NAS Utils:
http://bit.ly/1aDvkgR
Message 2 of 16
ScottChapman
Apprentice
Right, I have it installed on my tablet, when I run it and look at Telemetry(iStat) it reminds me that I need an add-on (which I have installed on my NAS) and then proceeds to tell me I need an iStat passcode, and to check my configuration...
Message 3 of 16
InTheShires
Tutor
FIVE Bucks?! Is there anything cheaper you could recommend?
(Sorry for hijacking thread slightly)
Message 4 of 16
ScottChapman
Apprentice
It's free on the android. But my experience is above... No idea not to establish my "passcode"
Or stated different, there is no charge for the one I can't get to work! 😉
Message 5 of 16
doylmi
Guide
No problem, please use the following steps:
[list=a:3hvn35tz]
  • Go to the main screen (the one that lists your NAS device(s)).
  • Press and hold your finger on the one you want to update the passcode for.
  • Click "Edit" when the context menu pops up
  • Scroll to the bottom, and update the passcode
  • Press save
  • I'll make sure this is clearer in the next iteration. Will probably prompt for the passcode iStat is detected, but the passcode is missing.
    Message 6 of 16
    ScottChapman
    Apprentice
    OK, I'll try that. Are you the author of the android app?
    Message 7 of 16
    doylmi
    Guide
    Yes, I am.
    Message 8 of 16
    ScottChapman
    Apprentice
    [list=a:3c0klogw]
  • Press save
    So, I see how to enter my passcode, but my question was really what is my passcode??? I do not know how to establish or otherwise determine what my passcode is...
    Message 9 of 16
    ScottChapman
    Apprentice
    [list=a:3ls9fup8]
  • Press save
    Also, when I installed iStat on my NAS, I got a share (that appears to be empty) than is snapshotting ever hour.
    Message 10 of 16
    doylmi
    Guide
    I can't comment on the share, but the "default password" that displays on the Apps tab is the passcode. I believe this is 12345. super-poussin is the maintainer for the iStat "app" for ReadyNAS if you have questions specifically regarding iStat.
    Message 11 of 16
    super_poussin
    Virtuoso
    Yep that's 12345 by default as written on the frontview interface
    Message 12 of 16
    doylmi
    Guide
    How'd it go? 🙂
    Message 13 of 16
    ScottChapman
    Apprentice
    doylmi wrote:
    How'd it go? 🙂
    Got it. THanks!
    Message 14 of 16
    doylmi
    Guide
    This has been implemented.
    Message 15 of 16
    ReadyAS
    I will describe my case I had on RNDP4000 with OS6:
    The stat daemon did not started, so I tried to run it manualy:
    root@nas:/apps/istat/bin# ./istatd
    and I saw the message:
    "Could not read configuration from /usr/local/etc/istat.conf: No such file or directory
    root@nas:/apps/istat/bin# more istatd"
    So I copied istat.conf:
    root@nas:/apps/istat/bin# cp -p /etc/istat.conf /usr/local/etc/
    Since this time there was not problem tu run the stat daemon from UI using ON/OFF switch, but still the main RUN button is inactive.
    Iteresting that:
    "root@nas:/apps/istat/bin# ps -ef|grep istat
    admin 18717 1 0 18:45 ? 00:00:00 /apps/istat/bin/istatd -d -c /etc/istat.conf"
    I mean "/etc/istat.conf" is as a parameter and "/usr/local/etc/istat.conf" is used in reality? Is the second path hardcoded?
    Message 16 of 16
    Discussion stats
    • 15 replies
    • 9553 views
    • 0 kudos
    • 5 in conversation
    Announcements
