- Subscribe to RSS Feed
- Mark Topic as New
- Mark Topic as Read
- Bookmark
- Subscribe
- Printer Friendly Page
readynas duo and 1100 probleme with SSL
- Mark as New
- Bookmark
- Subscribe
- Permalink
Avec la mise à jour des navigateurs et l'abandon de certains protocoles, il est impossible d'entrer sur la partie administration.
J'ai un readynas duo et un 1100
Le 1100 est avec une version RAIDiator 4.1.16.
J'ai finalement reussi à installer un vieux firefox v45 et à entrer mais aucune option, pas de possibilité de mettre à jour. Pas de projet open permettant de faire moi même la modification.
Y'a t'il une solution pour continuer à utiliser le materiel avec les versions recentes des navigateurs?
merci pour votre aide.
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Mark as New
- Bookmark
- Subscribe
- Permalink
Re: readynas duo and 1100 probleme with SSL
Hi,
is not a solution, i prefer use an old version of firefox on a dedicated computer that accept flux in http only.
why create a community website if is not possible to share code for very old version that you don't want manage on security update
regards
- Mark as New
- Bookmark
- Subscribe
- Permalink
Feel free to share away. Netgear has always made their Linux core source available, so have at it. But best of luck putting together a development environment for the custom SPARC processor and finding what you need to add an SSL update to the very old Linux core of that machine.
A user has already made available updates for OS 4.2.x (for Intel based legacy NAS) and 5.x (for ARM legacy NAS) so maybe somebody will do the same for 4.1.x. But the fact that nobody has done so in no way indicates that it's not allowed here. Netgear announced quite a long time ago that they would not be providing any new updates, so it's just been a matter of time before those hanging on to theor old hardware ran into a problem like this.
- Mark as New
- Bookmark
- Subscribe
- Permalink
To be clear - neither @Sandshark nor I work for Netgear.
@noeper wrote:is not a solution, i prefer use an old version of firefox on a dedicated computer that accept flux in http only.
I pointed out the lack of encryption in the workaround post - since it is clear that enterprise folks in particular might find that unacceptable. Though continuing to use TLS 1.0/1.1 in an enterprise is likely equally unacceptable. Still, if you prefer using an old version of firefox, then of course you can do that.
As far as home use goes
- home routers similarly use http for local administration.
- we are talking about an ancient version of linux that hasn't received a backported security update from Netgear in 5 years. So IMO you can't assume that a 4.1.x NAS is secured from current attacks anyway. You are depending on the edge security from your router.
As @Sandshark says, it would be great if you (or someone else) can provide a TLS 1.2 add-on for 4.1.x systems that is similar to what @WhoCares_ has already provided for 4.2.x and 5.3.x systems.
