× NETGEAR will be terminating ReadyCLOUD service by July 1st, 2023. For more details click here.
Orbi WiFi 7 RBE973
Reply
6.9.3 Enhance MacOS Drag and Drop files to 0kb
aequus
Changing Timemashine (TM) to SMB enabled the Enhance MacOS feature in SMB sttings. Afterward I had problemes in MAC Outlook 2016. Dragging an attachment to a NAS folder will cause a 0kb file. The same happend in finder by dragging a file from one NAS folder to another, the copie file size is 0kb.
First I had to set TM back to AFP and then I could disable the "Enhance MacOS" in SMB settings. No Drag and drop is working again.
Model: RN51600|ReadyNAS 516 6-Bay
Message 1 of 5
JohnCM_S
NETGEAR Employee Retired
Re: 6.9.3 Enhance MacOS Drag and Drop files to 0kb
Hi  aequus,
Are you still having this issue on your NAS? If yes, can you provide the system logs to us. You may visit this link for the steps on how you can provide the logs.
Message 2 of 5
Ki_Adi_Mundi
NETGEAR Expert
Hi Aequus,
I didn't get idea from the logs,  do you still see the issue ?
Message 3 of 5
aequus
I re enabled "enhanced mac os" and rebooted the nas. Afterwards I had the the some problems again. Draiging attachments from Mac Outlook to nas will caus 0kb file.
Message 4 of 5
Ki_Adi_Mundi
NETGEAR Expert
does drag local files to NAS work?   what's the MacOS version you are using?
Message 5 of 5
Top Contributors
Discussion stats
  • 4 replies
  • 1319 views
  • 0 kudos
  • 3 in conversation
Announcements
