× NETGEAR will be terminating ReadyCLOUD service by July 1st, 2023. For more details click here.
Orbi WiFi 7 RBE973
Reply
Adaptive Load Balancing
dtsteinb
I have the 2 NIC cards in my switch and when I went to create a new bond and use  Adaptive Load Balancing I lost all access to it.  I had to turn it off, unplug the ethernet cables and various other things until it finally came back but it doesn't appear to be bonded.
Is there something speical I need to do?  I thought a special switch was not needed for this type of bonding?
I thought I could do this during business hrs, if it dropped for a minute I could deal with that but this took 30 minutes before I could get it back online
Model: RN21242E|ReadyNAS 2120 1U 4- Bay 4x2TB Enterprise Drive
Message 1 of 5
Guru
Re: Adaptive Load Balancing
It isn't, but I've seen some other cases where it misbehaves.  Full loss of network is worse than the other cases I heard of.
Perhaps try TLB and see if it works out better.
Message 2 of 5
dtsteinb
Would Round Robin be better?
Message 3 of 5
Guru
Yes, but Round Robin requires switch support (setting up a static LAG on the switch).
Message 4 of 5
dtsteinb
Will try TLB first then.
Message 5 of 5
Top Contributors
Discussion stats
  • 4 replies
  • 1729 views
  • 0 kudos
  • 2 in conversation
Announcements
