× NETGEAR will be terminating ReadyCLOUD service by July 1st, 2023. For more details click here.
Orbi WiFi 7 RBE973
Reply
Lose LDAP Connection - Active Directory Domain Services
hinze555
HI!
I've just upgraded to FWV 6.7.1 to check if that issue persists - it does.
Since a few days we have an event on the server logs from the active directory domain service, that the Readynas loses the LDAP connection every half an hour or so. We've double checked the connection cables - all fine. The nas is joined to the domain as well. I've also left the domain and re joined it again but the issue persists. has anyone experience with this error?
Readynas 202 on FWV 6.7.1
On the serverlogs it says:
"Internal event: An LDAP client connection was closed because of an error.
Client IP:
192.168.1.XXX:46266
Additional Data
Error value:
1236 Die Netzwerkverbindung wurde durch das lokale System getrennt.
"The connection was closed by the system due to an error.."
Internal ID:
c060382
Hinze
Message 1 of 5
Accepted Solutions
hinze555
Re: Lose LDAP Connection - Active Directory Domain Services
Hi Jenn!
The error started a few weeks ago. It did not work with the prvious version of the RN Firmware.
I asume it is some kind of windows issue - though it is harmless acording th this MS Article: https://support.microsoft.com/en-us/help/246717/numerous-event-id-1216-events-in-directory-services-...
Maybe it disapears as it apeared... 🙂
Hinze
Message 3 of 5
All Replies
JennC
NETGEAR Employee Retired
Hello hinze555,
Was this working flawlessly prior to update to 6.7.1?
Please send system logs and include the link to this topic with a short summary of the problem.
Welcome to the community!
Message 2 of 5
hinze555
Hi Jenn!
Hinze
Message 3 of 5
JennC
Hello hinze555,
It occurs only if the diagnostic logging level is increased by modifying the level of LDAP logging to 2 or above in the registry.
So, I checked the link, yes, it appears to be something with Windows and harmless. I guess for now, we may consider this topic close.
Thank you for sending the link, by the way.
Message 4 of 5
JennC
Hello hinze555,
If your issue is now resolved, we encourage you to mark the appropriate reply as the “Accept as Solution” or post what resolved it and mark it as solution so others can be confident in benefiting from the solution.
The Netgear community looks forward to hearing from you and being a helpful resource in the future!
Message 5 of 5
Top Contributors
Discussion stats
  • 4 replies
  • 10135 views
  • 0 kudos
  • 2 in conversation
Announcements
