× NETGEAR will be terminating ReadyCLOUD service by July 1st, 2023. For more details click here.
Orbi WiFi 7 RBE973
Reply
Mac finder issues using SMB
grahami
Hi
We are using an application (Egnyte) that requires SMB connections, however we have issues with Mac users connected to the ReadyNAS via SMB.
The issues range from not being able to see folder updates made by other users (finder seems to be caching the folder names) to losing permissions on the share when someone else makes changes. Disconnecting and then reconnecting gets you back to a good connection with all updates. The cause seems to be the Mac Finder and implementation of SMB, just wondering if anyone else has come across this and has any solutions.
Thanks
Graham
PS - We are also talking to Egnyte about this issue to see if they can help, just trying a two pronged approach by asking here
Model: RN4220X|ReadyNAS 4220 10Gbase-T
Message 1 of 9
JennC
NETGEAR Employee Retired
Re: Mac finder issues using SMB
Hello grahami,
Maybe it is best to check if you get the same problem on other Mac connecting to the volume of the NAS as well Windows.
Can you also provide the model number and firmware version of your NAS?
Welcome to the community!
Message 2 of 9
JennC
Hello grahami,
We’d greatly appreciate hearing your feedback letting us know if the information we provided has helped resolve your issue or if you need further assistance.
If your issue is now resolved, we encourage you to mark the appropriate reply as the “Accept as Solution” or post what resolved it and mark it as solution so others can be confident in benefiting from the solution.
The Netgear community looks forward to hearing from you and being a helpful resource in the future!
Message 3 of 9
grahami
Hi
Thanks for the reply
The model is a 4220X and the firmware is the latest, 6.6
The issue happens for all the Macs connected to the ReadyNAS shares, it isnt just one of them
Graham
Message 4 of 9
JennC
Hello grahami,
Do the Mac machines have the same version? I haven't heard of this problem. Will it be possible to test this on a Windows version?
Message 5 of 9
grahami
All Macs are running El Capitan
We have Windows users and they do not have any issues, it is only the Macs who have these issues
Message 6 of 9
mdgm-ntgr
Hi grahami,
Any update?
Do you still have this problem?
Message 7 of 9
grahami
Still have the same issue, it seems to be the way Apple have implemented SMB and the application we are using requires SMB - they plan an update this half year, so we have to struggle on until then
Message 8 of 9
mdgm-ntgr
What update are you referring to and has that been released yet? Egnyte? Something else?
Message 9 of 9
Top Contributors
Discussion stats
  • 8 replies
  • 3070 views
  • 0 kudos
  • 3 in conversation
Announcements
