× NETGEAR will be terminating ReadyCLOUD service by July 1st, 2023. For more details click here.
Orbi WiFi 7 RBE973
Reply
No access to admin webinterface during raid rebuild
stopgapit
The readynas 104 web interface has died during data rebuild, i can ping the device but no web GUI.
The LCD display status: Booting     ( for last 2 hours )
It's running firmware 6.4.2
 Action performed: Rebooted the unit but it's in the same state and blue led is blinking rapidly with lcd display "booting"
Model: ReadyNAS-OS6|
Message 1 of 3
BrianL2
NETGEAR Employee Retired
Re: No access to admin webinterface during raid rebuild
Hi stopgapit,
I suppose that you can't also access your files. If you want to access or backup your files,boot the unit in volume read-only mode. Also, can you tell us the most recent changes you made on your system that might have caused this?
Kind regards,
BrianL
NETGEAR Community Team
Message 2 of 3
mdgm-ntgr
Getting stuck on booting could also possibly indicate there is another failed disk. Did you check the SMART stats of the disks before adding/replacing a disk?
Message 3 of 3
Top Contributors
Discussion stats
  • 2 replies
  • 2586 views
  • 0 kudos
  • 3 in conversation
Announcements
