× NETGEAR will be terminating ReadyCLOUD service by July 1st, 2023. For more details click here.
Orbi WiFi 7 RBE973
Reply
ReadyNas Pro 2 latest firmware
ddawson100
What's the latest firmware rev? We want to update this to support Egnyte Storage Sync 11 but it looks like we need to get our ReadyNAS up to the 6.7.1 firmware. I see from the download page that the newest is RAIDiator 4.2.31. Are we out of luck? Do we need to replace our device!?
Hostname: [xxxxxxxxxxxxxx]
Model: ReadyNAS Pro 2 [X-RAID2]
Serial: [xxxxxxxxxxxxxx]
Firmware: RAIDiator 4.2.27
Memory: 1024 MB [DDR3]
IPv4 address: 1: Not Connected
IPv4 address: 2: 192.168.xx.xxxx
Volume C: Online, X-RAID2, 2 disks, 5% of 1841 GB used
Model: RNDP2000 (ReadyNAS Pro 2)|ReadyNAS® Pro 2 System Diskless|EOL
Message 1 of 4
Accepted Solutions
JohnCM_S
NETGEAR Employee Retired
Re: ReadyNas Pro 2 latest firmware
Hi ddawson100,
Welcome to the Community!
We always suggest that it will be best to replace your chassis with our newer models that has the OS6 firmware.
Some users here in the Community were able to convert their 4.2.x NAS to OS6. This can also work for you, although this is not supported by NETGEAR. You may check this thread for the steps.
The files you need to convert your Pro 2 to OS6 can be found here.
Message 2 of 4
All Replies
JohnCM_S
Hi ddawson100,
Message 2 of 4
ddawson100
Thanks. We'll consider this approach but replacing with a device that natively supports the proper OS makes a lot more sense.
Message 3 of 4
Guru
@ddawson100 wrote:
...replacing with a device that natively supports the proper OS makes a lot more sense.
That is @JohnCM_S' main recommendation, the conversion was an alternative.
If you do get a new main NAS (perhaps in the RN420 series), then I recommend repurposing the Pro-2 as a local backup (in addition to the Egynte cloud backup).
Message 4 of 4
Top Contributors
Discussion stats
  • 3 replies
  • 3008 views
  • 1 kudo
  • 3 in conversation
Announcements
