× NETGEAR will be terminating ReadyCLOUD service by July 1st, 2023. For more details click here.
Orbi WiFi 7 RBE973
Reply
Readynas NV LED error codes #1,3,4 then #2
rick_goeverett_
My ReadyNas NV (not NV+) displays lights #1.3 and 4, then changes to #2 only. then back and forth at 1 sec intervals, this has gone on for several days.
Can't find a list of error codes by lights.
Raidar can't find it.
I removed the four 500G drives and tried four new 2TB drives, no change.
Tried the drives in a different order, no change.
Tried no drives, no change
Tried the reset, no change
Message 1 of 3
rick_goeverett_
Re: Readynas NV LED error codes #1,3,4 then #2
Found an error sheet on a different drive which stated two errors 134 and just #2
#2 was reseat or replace DIMM, that worked.
Thanks to all
Message 2 of 3
stevebower
Same here - massive panic, til found the answer. Thanks. That'll teach me to fiddle!
*no it won't
Message 3 of 3
Top Contributors
Discussion stats
  • 2 replies
  • 3747 views
  • 0 kudos
  • 2 in conversation
Announcements
