- Subscribe to RSS Feed
- Mark Topic as New
- Mark Topic as Read
- Bookmark
- Subscribe
- Printer Friendly Page
Unable to access Admin page, not showing anymore in explorer after updating Firmware #26923836
- Mark as New
- Bookmark
- Subscribe
- Permalink
Hi, I just upgraded from 6.4.2 to 6.5.0
Before I reboot:
Unable to access admin page, was getting a loading bar with NetGear logo, than getting a connection error message.
I was able to see my NAS in explorer and browse files.
I rebooted and now this is happening:
I'm getting connection error when tring to access the admin page. -Default error like if there wasn't anything at that address. Same thing when I use the IP address.
I can ping the Ip and getting a immediate response.
I found a few indication that i should be able to login in SSH with putty but it's not working for me.
The LCD screen show the right host name and version. I also got a message to get the encryption key on boot.
Not sure what i can do at this point...
Solved! Go to Solution.
Accepted Solutions
- Mark as New
- Bookmark
- Subscribe
- Permalink
We tried OS-Reinstall and nothing changed.
We tried unplugin one ethernet, nothing changed.
The issue was escalated to lvl 3. They entered in tech mode.
They find out that one of my 2 HDDs didn't sync properly and corrupted some system files. I simply removed that HDD and rebooted normaly. Everything was okay.
I put back the bad HDD and started resync.
hope it helps someone else.
P.S. Netgear costumer service is good and fast - recommended! 😄
All Replies
- Mark as New
- Bookmark
- Subscribe
- Permalink
Re: Unable to access Admin page, not showing anymore in explorer after updating Firmware
Are you using the correct IP address, it may have changed?
You can check it on the LCD screen or using Raidar 6
Also try using the IP address \\xxx.x.x.x/admin instead of the Hostname
Also clear your browser cache
- Mark as New
- Bookmark
- Subscribe
- Permalink
Hi Vinz,
Welcome to the community!
Try clearing the browser cache, another web browser or use a private / incognito window.
Hope this helps!
Kind regards,
BrianL
NETGEAR Community Team
- Mark as New
- Bookmark
- Subscribe
- Permalink
Hi Vinz,
We’d greatly appreciate hearing your feedback letting us know if the information we provided has helped resolve your issue or if you need further assistance.
If your issue is now resolved we encourage you to mark the appropriate reply as the “Accepted Solution” so others can be confident in benefiting from the solution. The Netgear community looks forward to hearing from you and being a helpful resource in the future!
Thanks,
- Mark as New
- Bookmark
- Subscribe
- Permalink
Re: Unable to access Admin page, not showing anymore in explorer after updating Firmware #26923836
Still not fixed. Currently working this case with help desk.
So far we tried reinstalling OS and clearing browser cache. Nothing as changed, same issue persist.
- Mark as New
- Bookmark
- Subscribe
- Permalink
Have you tried disconnecting one of the ethernet cables from the NAS to see if that helps?
RAIDar shows the NAS is up with two different I.P.s
I hear you've done an OS Re-install. If you had LACP enabled on the switch try disabling that or temporarily connecting the NAS to a different port.
If you were using teaming on the NAS side an OS Re-install would have reset the network settings back to not using that and also picking up an I.P. address for each NIC via DHCP.
- Mark as New
- Bookmark
- Subscribe
- Permalink
