- Subscribe to RSS Feed
- Mark Topic as New
- Mark Topic as Read
- Bookmark
- Subscribe
- Printer Friendly Page
Volume full full with 4TB free
- Mark as New
- Bookmark
- Subscribe
- Permalink
I have a ReadyNas 3130 with 4 3TB drives. Recently my back up application stated to fail because it could not write to the storage drive indicating that the drive was full. Under the system tab of the device, the data indicator shows that there was 4TB free of 8.17 TB but the log files indicated that the device was at 90% of its storage capacity, so what gives. I had to delete some of my backup data in order to write to the device. I upgrade the firmware to 6.6.1 and I guess I will have to wait to see if that fixes the problem. Is there something in the setting that I am missing or is this a known issue. I have 4 3TB drives (ST3000NM0033) in the device, Raid 5, X-Raid.
- Mark as New
- Bookmark
- Subscribe
- Permalink
Re: Volume full full with 4TB free
If Antivirus is still enabled, please disable and reboot. Hopefully it gets better then.
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Mark as New
- Bookmark
- Subscribe
- Permalink
Which backup application? Some wrongly configured application may back up the data to the OS volume, which is 4GB of capacity.
How much data do you in this specific backup? (If it's more than 4GB, it means that's not the problem).
Can you download the logs from the GUI and paste here the beginning of the btrfs.log please?
- Mark as New
- Bookmark
- Subscribe
- Permalink
The backup software is MSP backup and recovery. The backups are being stored in the correct location. The log files ave been cleared
- Mark as New
- Bookmark
- Subscribe
- Permalink
btrfs.log is generated on demand when downloading the logs so even if you "cleared" the logs that log would still have useful information.
- Mark as New
- Bookmark
- Subscribe
- Permalink
OK, here is the log
Label: '2fe5a72a:root' uuid: d87d054b-b8e0-43b4-87ba-568d9477a858 Total devices 1 FS bytes used 488.07MiB devid 1 size 4.00GiB used 2.43GiB path /dev/md0 Label: '2fe5a72a:data' uuid: 694375eb-6a06-45f7-aa45-ca703baee6b5 Total devices 1 FS bytes used 2.85TiB devid 1 size 8.17TiB used 7.80TiB path /dev/md127 === filesystem /data === Data, single: total=7.80TiB, used=2.85TiB System, DUP: total=8.00MiB, used=896.00KiB System, single: total=4.00MiB, used=0.00B Metadata, DUP: total=1.50GiB, used=671.00MiB Metadata, single: total=8.00MiB, used=0.00B GlobalReserve, single: total=224.00MiB, used=0.00B === subvolume /data === ID 256 gen 176008 top level 5 path home ID 257 gen 182811 top level 5 path .apps ID 258 gen 7 top level 5 path .vault ID 259 gen 182811 top level 5 path .timemachine ID 260 gen 182808 top level 5 path Serverbackupd ID 261 gen 176012 top level 5 path ._share ID 262 gen 31 top level 260 path Serverbackupd/.snapshots ID 263 gen 73615 top level 5 path FTP ID 264 gen 37 top level 263 path FTP/.snapshots ID 265 gen 41 top level 256 path home/xxxx ID 266 gen 3834 top level 256 path home/xxxxx ID 267 gen 73609 top level 256 path home/xxxxx === btrfs-show-super /dev/md0 /dev/md127 superblock: bytenr=65536, device=/dev/md0 --------------------------------------------------------- csum_type 0 (crc32c) csum_size 4 csum 0xf27f3862 [match] bytenr 65536 flags 0x1 ( WRITTEN ) magic _BHRfS_M [match] fsid d87d054b-b8e0-43b4-87ba-568d9477a858 label 2fe5a72a:root generation 961169 root 90128384 sys_array_size 226 chunk_root_generation 958210 root_level 0 chunk_root 20987904 chunk_root_level 0 log_root 0 log_root_transid 0 log_root_level 0 total_bytes 4290772992 bytes_used 511782912 sectorsize 4096 nodesize 16384 leafsize 16384 stripesize 4096 root_dir 6 num_devices 1 compat_flags 0x0 compat_ro_flags 0x0 incompat_flags 0x21 ( MIXED_BACKREF | BIG_METADATA ) cache_generation 18446744073709551615 uuid_tree_generation 961169 dev_item.uuid 3990deb3-8f90-40f7-ab01-ca4491f76c9c dev_item.fsid d87d054b-b8e0-43b4-87ba-568d9477a858 [match] dev_item.type 0 dev_item.total_bytes 4290772992 dev_item.bytes_used 2612068352 dev_item.io_align 4096 dev_item.io_width 4096 dev_item.sector_size 4096 dev_item.devid 1 dev_item.dev_group 0 dev_item.seek_speed 0 dev_item.bandwidth 0 dev_item.generation 0 superblock: bytenr=65536, device=/dev/md127 --------------------------------------------------------- csum_type 0 (crc32c) csum_size 4 csum 0xf29571cc [match] bytenr 65536 flags 0x1 ( WRITTEN ) magic _BHRfS_M [match] fsid 694375eb-6a06-45f7-aa45-ca703baee6b5 label 2fe5a72a:data generation 182811 root 421265408 sys_array_size 226 chunk_root_generation 182732 root_level 1 chunk_root 21069824 chunk_root_level 1 log_root 0 log_root_transid 0 log_root_level 0 total_bytes 8986874216448 bytes_used 3133635477504 sectorsize 4096 nodesize 32768 leafsize 32768 stripesize 4096 root_dir 6 num_devices 1 compat_flags 0x0 compat_ro_flags 0x0 incompat_flags 0x21 ( MIXED_BACKREF | BIG_METADATA ) cache_generation 18446744073709551615 uuid_tree_generation 182811 dev_item.uuid 05a82a71-618f-45b3-8b26-b4a47e6aa18e dev_item.fsid 694375eb-6a06-45f7-aa45-ca703baee6b5 [match] dev_item.type 0 dev_item.total_bytes 8986874216448 dev_item.bytes_used 8648424882176 dev_item.io_align 4096 dev_item.io_width 4096 dev_item.sector_size 4096 dev_item.devid 1 dev_item.dev_group 0 dev_item.seek_speed 0 dev_item.bandwidth 0 dev_item.generation 0
- Mark as New
- Bookmark
- Subscribe
- Permalink
That looks fine, but you could run a balance of your data volume if you want.
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Mark as New
- Bookmark
- Subscribe
- Permalink
Go to System > Volumes, click on the Settings wheel for your volume and choose to run a Balance.
