markvg1's avatar
markvg1
Disk 2 Dead - But not - Ready NAS NV+ V2
Hi All,
Ok so I got a brand new unit after my first one was faulty -> viewtopic.php?f=65&t=62131
Config:
Netgear ReadyNAS NV+ V2
Radiator 5.3.4
256MB RAM
4 * 2TB WD20EARX HDD's (per the approved hardware list) - Brand New
No UPS
No USB
Disk configured as JBOD
All worked well this time on the set up.
2 days in Disk 2 is failed - no worries, i put in a new 2tb identical disk as above. factory default the unit and configure as JBOD.
1 night goes past - disk 2 failed again!
So i did some digging, I can browse to the drive just fine (as it is configured as JBOD I know what shares are on that disk). Once I am using the drive everything appears normal - the error disapears from the ready nas display and all is fine again 20 mins later device spins down and I get the same error. I believe this to be weird because both disks are new and non sequential serial numbers.
The whole time (failed disk or not) Raidar shows all green and when I log into to raidiator all drives are healthy etc...
I called support and the tech said to cehck out the smart logs - all had no errors reported - see below for the logs for drive two.
So am I missing something? is it something I have to live with and the disk is fine?
As a side note - my issues from the 1st device started with a faulty drive error message. On bay 2!
Thanks in advance for any assistance you can provide for this matter - I have searched the forums with no luck.
***** Disk SMART log for channel 2 [sdb] *****
smartctl 5.40 2010-07-12 r3124 [armv5tel-unknown-linux-gnueabi] (local build)
Copyright (C) 2002-10 by Bruce Allen, http://smartmontools.sourceforge.net
=== START OF INFORMATION SECTION ===
Device Model: WDC WD20EARX-00PASB0
Serial Number: XXXXXXXXXXXXXXXXXXX
Firmware Version: 51.0AB51
User Capacity: 2,000,398,934,016 bytes
Device is: Not in smartctl database [for details use: -P showall]
ATA Version is: 8
ATA Standard is: Exact ATA specification draft version not indicated
Local Time is: Sat Apr 14 11:32:34 2012 PDT
SMART support is: Available - device has SMART capability.
SMART support is: Enabled
=== START OF READ SMART DATA SECTION ===
SMART overall-health self-assessment test result: PASSED
General SMART Values:
Offline data collection status: (0x82) Offline data collection activity
was completed without error.
Auto Offline Data Collection: Enabled.
Self-test execution status: ( 0) The previous self-test routine completed
without error or no self-test has ever
been run.
Total time to complete Offline
data collection: (37080) seconds.
capabilities: (0x7b) SMART execute Offline immediate.
Auto Offline data collection on/off support.
Suspend Offline collection upon new
command.
Offline surface scan supported.
Self-test supported.
Conveyance Self-test supported.
Selective Self-test supported.
SMART capabilities: (0x0003) Saves SMART data before entering
power-saving mode.
Supports SMART auto save timer.
Error logging capability: (0x01) Error logging supported.
General Purpose Logging supported.
Short self-test routine
recommended polling time: ( 2) minutes.
Extended self-test routine
recommended polling time: ( 255) minutes.
Conveyance self-test routine
recommended polling time: ( 5) minutes.
SCT capabilities: (0x3035) SCT Status supported.
SCT Feature Control supported.
SCT Data Table supported.
SMART Attributes Data Structure revision number: 16
Vendor Specific SMART Attributes with Thresholds:
ID# ATTRIBUTE_NAME FLAG VALUE WORST THRESH TYPE UPDATED WHEN_FAILED RAW_VALUE
1 Raw_Read_Error_Rate 0x002f 200 200 051 Pre-fail Always - 0
3 Spin_Up_Time 0x0027 167 165 021 Pre-fail Always - 6625
4 Start_Stop_Count 0x0032 100 100 000 Old_age Always - 228
5 Reallocated_Sector_Ct 0x0033 200 200 140 Pre-fail Always - 0
7 Seek_Error_Rate 0x002e 100 253 000 Old_age Always - 0
9 Power_On_Hours 0x0032 100 100 000 Old_age Always - 344
10 Spin_Retry_Count 0x0032 100 100 000 Old_age Always - 0
11 Calibration_Retry_Count 0x0032 100 253 000 Old_age Always - 0
12 Power_Cycle_Count 0x0032 100 100 000 Old_age Always - 71
192 Power-Off_Retract_Count 0x0032 200 200 000 Old_age Always - 66
193 Load_Cycle_Count 0x0032 197 197 000 Old_age Always - 11288
194 Temperature_Celsius 0x0022 122 109 000 Old_age Always - 28
196 Reallocated_Event_Count 0x0032 200 200 000 Old_age Always - 0
197 Current_Pending_Sector 0x0032 200 200 000 Old_age Always - 0
198 Offline_Uncorrectable 0x0030 200 200 000 Old_age Offline - 0
199 UDMA_CRC_Error_Count 0x0032 200 200 000 Old_age Always - 0
200 Multi_Zone_Error_Rate 0x0008 200 200 000 Old_age Offline - 0
SMART Error Log Version: 1
No Errors Logged
SMART Self-test log structure revision number 1
Num Test_Description Status Remaining LifeTime(hours) LBA_of_first_error
# 1 Short offline Completed without error 00% 344 -
# 2 Short offline Completed without error 00% 315 -
# 3 Short offline Interrupted (host reset) 80% 272 -
# 4 Short offline Completed without error 00% 249 -
# 5 Short offline Interrupted (host reset) 80% 221 -
# 6 Short offline Interrupted (host reset) 90% 174 -
# 7 Short offline Completed without error 00% 152 -
# 8 Short offline Interrupted (host reset) 80% 126 -
# 9 Short offline Completed without error 00% 118 -
#10 Short offline Completed without error 00% 0 -
SMART Selective self-test log data structure revision number 1
SPAN MIN_LBA MAX_LBA CURRENT_TEST_STATUS
1 0 0 Not_testing
2 0 0 Not_testing
3 0 0 Not_testing
4 0 0 Not_testing
5 0 0 Not_testing
Selective self-test flags (0x0):
After scanning selected spans, do NOT read-scan remainder of disk.
If Selective self-test is pending on power-up, resume after 0 minute delay.
  • mdgm-ntgr's avatar
    mdgm-ntgr
    NETGEAR Employee Retired
    Can you power down, remove the disk and connect it to an internal SATA port in your PC and test it using WD LifeGuard Diagnostics?
  • evan2's avatar
    evan2
    NETGEAR Expert
    This is a known issue, it drop the partitions on md0 which is builded as RAID 1 and installed ReadyNAS system, data is stored in md2, so don't worry, the issue don't affect your data, please reboot the unit, the missed partitions on md0 will be recovery, we are debugging the issue.
    You can run command" cat /proc/mdstat" to check partitions on md0 and md2.
  • I was having a similar problem with my Ready NAS NV+ v2. I have 4 3TB Seagate Barracuda 7200.14 ST3000DM001 which are on the HCL. It kept stating disk 1 or 2 failed and after a reboot or two it started syncing. After I switched it from Xraid2 to flexraid the drive failures ceased. I have not had any problems with disk failures since which has been a month so far.
    Config:
    Radiator 5.3.4
    256MB RAM
    Flex-raid 5
ProSupport for Business
