atwatermalick's avatar
Jul 06, 2018
Is there a way to change how often Dropbox Syncs on a ReadyNAS 422?
Is there a way to set the timeframe for the Dropbox Sync? I have it setup Bidirectional in case a file is changed on the local drive or the dropbox folder. I created a test folder in both places and it hasn't shown up for over an hour
Thanks,
John
  • JohnCM_S's avatar
    JohnCM_S
    NETGEAR Employee Retired
    Hi atwatermalick,
    Welcome to the Community!
    Dropbox sync is only real-time and there is no option to change that either on the ReadyNAS or Dropbox.
    You may try assigning a static DNS on the NAS and see if there will be any activities on the Dropbox sync afterwards.
  • JohnCM_S's avatar
    JohnCM_S
    Hi atwatermalick,
    We’d greatly appreciate hearing your feedback letting us know if the information we provided has helped resolve your issue or if you need further assistance.
    If your issue is now resolved, we encourage you to mark the appropriate reply as the “Accept as Solution” or post what resolved it and mark it as solution so others can be confident in benefiting from the solution.
    The Netgear community looks forward to hearing from you and being a helpful resource in the future!
ProSupport for Business
