Wally_85's avatar
Wally_85
Follower
Nov 18, 2024
Collegare XR1000 a linea ftth wind
Salve, mi hanno installato una linea fibra ftth wind con media converter tp link(MC220L), e vorrei sapere quali sono le configurazioni per farlo funzionare con il modem xr1000.
Grazie
1 Reply
  • You may require PPPoE/VLAN for example, if you don't know then you should contact your internet provider to double check. Otherwise there is nothing specific you need to do, other than completing the XR Setup Wizard if this is your first time setting up or have factory reset.
