Rispondere
Highlighted
Follower
Netgear base vmb3000
I'm trying to connect my base station and cameras.
The Arlo phone app does not recognize a base station or a camera when it's looking for them it continues looking for them forever and no devices are recognized.
Everything was working fine except as time went on one by one of the cameras would disconnect and it would never work properly again. The remote cameras that run on batteries and the cameras that plug in are not recognized.
Will a factory reset Bulbasaur should I just send the entire thing back
Messaggio 1 di 2
Highlighted
NETGEAR Employee Retired
Re: Netgear base vmb3000
Gentile @Makapuu
bentornato nella community!
Per quanto riguarda i prodotti ARLO, la invitiamo a contattare direttamente il loro supporto.
Saluti
Marco
Team NETGEAR
Dear @Makapuu
welcome back to the community!
As for ARLO products, we invite you to contact their support directly.
Regards
Marco
NETGEAR team
____
Gentilmente clicchi KUDOS se ha trovato la risposta utile e ACCETTARE COME SOLUZIONE se opportuno.
Messaggio 2 di 2
Statistiche discussione
  • 1 risposta
  • 369 visualizzazioni
  • 0 kudos
  • 2 con conversazione attiva
