Grix's avatar
Grix
Follower
Jul 11, 2011
Need SIP VOIP QoS best practices for FVS336
We have a number of SIP (UDP) VOIP phones in our office and I am trying to prioritize their traffic through our FVS336v2.
Our FVS336 is in failover mode. We have a 50/5Mb cable business internet service (WAN1) and a 6Mb DSL as the failover connection (WAN2).
The phones are on the same subnet as the rest of the network, but are set up in a specific IP range (x.x.x.110-120).
My desire is to make sure that the phones have absolute priority over all other traffic (both incoming and outgoing) to maximize sound quality at all times.
Is there a "best practices" combination of rules, bandwidth profiles and QoS prioritization to accomplish this? If not, does anyone know a really solid way to do it?
I'd like it to be 100% dynamic, but if I have to permanently set aside a chunk of the bandwith for the phones I will.
Thanks very much!
1 Reply
  • Grix,
    Were you able to find a solution to this question? I find myself in a similar situation. Voice Quality remains high when network usage is low - normal, though as upstream / downstream usage approaches maximum throughput voice quality drops off significantly.
    I am currently looking at bandwidth profiles as a possible solution though I am having difficulty getting them to function as expected.
ProSupport for Business
