StrikedOut
Dec 02, 2015Aspirant
Netgear FVS336Gv2 IPSec VPN with Shrew Soft client
I recently upgraded our FVS336Gv2 to firmware 4.3.3-6 from an older v3.x.x. I have reconfigured the firewall and it has internet connection and all is fine for that part of the equation. My issue lies with trying to get the VPN working with Shrew Soft, I keep getting the following error in the VPN logs;
[FVS336Gv2] [IKE] ERROR: Could not find configuration for 185.x.x.x[3255]
The 185.x.x.x is the public IP of the connection I am trying to remote from which is a different site to the one I trying to connect to.
I am running Win10 with no AV or firewall.
Any advise on getting this working?
- StrikedOutAspirant
Hi DaneA, thanks for the reply.
That was the walkthrough I used to get as far as I did and I just tried using my laptop which is Win8.1 and get the same error.
- DaneANETGEAR Employee Retired
Hi StrikedOut,
Let us isolate the problem. Here are my questions below:
a. Were you able to connect just fine using your Windows 10 PC with Shrew Soft Client software before you have upgraded the firmware of the FVS336Gv2?
b. Did you perform a factory reset on the FVS336Gv2 after successfully upgrading its firmware? It is recommended to reset the FVS336Gv2 to factory default settings after doing a firmware upgrade.
c. Is the LAN subnet set on your FVS336Gv2 differ from the LAN subnet of you existing local network where your Windows 10 PC with Shrew Soft Client software is connected to? For example, the FVS336Gv2 has a LAN subnet of 192.168.9.x while your existing local network where your Windows 10 PC belongs has a LAN subnet of 172.16.3.x. The LAN subnet should be different.
d. Is the WAN IP Address registered on the FVS336Gv2 a Public IP Address?
I look forward to your response.
DaneA
NETGEAR Community Team
