×  Introducing Nighthawk RS700 WiFi 7 (BE) Router. For more details, please visit Nighthawk Tri-Band WiFi 7 Router.
Reply
2.4 ghz not password protected
hnoble
Currently, my 5 ghz is password proteted but my 2.4 ghz is not. When I go and select this security option WPA2-PSK [AES] and add a password on it, it does not show that a password is needed. I would just make the 2.4 ghz unavailable except that we have products that can only be used on the 2.4. I there a way to make it secure beyond what I am doing?
Model: C6300|AC1750 Cable Modem Router Docsis 3.0
Message 1 of 8
Accepted Solutions
olympos1625
NETGEAR Employee Retired
Re: 2.4 ghz not password protected
@hnoble,
Thank you for the update. Did you try to reset the Cable gateway? If not yet please do so and set it up again and see if that resolves the issue.
Please do not hesitate to let me know if you need further assistance.
Oliver
Community Team
Message 8 of 8
All Replies
olympos1625
Hi hnoble,
Welcome to NETGEAR Community!
First of all, we do apologize for the inconvenience of not getting back to you immediately due to the backlog in the system. Do you still have this problem securing the 2.4 Ghz wireless network? Have you tried resetting the router? What is the model of your router?
Oliver
Community Team
Message 2 of 8
hnoble
Yes I am still having this problem. I have tried resetting multiple times. The model is a C6300v2. Attached are photos the illustrate the issue.  2.jpg1.jpg
Message 3 of 8
hnoble
Message 4 of 8
hnoble
Message 5 of 8
antinode
Guru
> [...] I there a way to make it secure beyond what I am doing?
   There should be, but how many of us know what you're doing?
> [...] I have tried resetting multiple times. [...]
   "tried" how, exactly?  What happened whan you did whatever you did?
   Visit http://netgear.com/support , put in your model number, and look
for Documentation.  Get the User Manual (at least).  Read.  Look for
"Factory Settings" and "Specify Basic WiFi Settings".  Is there a
non-empty passphrase for both radio bands?
Message 6 of 8
hnoble
I have already read through the documentation and reset to factory settings as described in the manual. That is why I have asked this question on the forum, as the current documentation was not helpful in resolving my issue.
Message 7 of 8
olympos1625
@hnoble,
Oliver
Community Team
Message 8 of 8
Discussion stats
  • 7 replies
  • 1378 views
  • 0 kudos
  • 3 in conversation
Announcements
Orbi WiFi 6E
