× Introducing the Orbi 970 Series Mesh System with WiFi 7 technology. For more information visit the NETGEAR Press Room.
Orbi WiFi 7 RBE973
Reply
5G on N300WNR2000v4
lemick
5G on N300WNR2000v4
N300 WNR2000 v4
The box says "Simultaneous Dual Band--runs 2.4 and 5GHz bands concurrently" but it connects only at 2.4. How do I get it to connect at 5?
Message 1 of 7
microchip8
Master
Re: 5G on N300WNR2000v4
Go to http://192.168.1.1 and check your settings?
Routing: NETGEAR RAX43 - Firmware: v1.0.15.128 (1 Gbps down, 40 Mbps up)
Switching: 2x NETGEAR 8-ports (GS108v4) / 1x NETGEAR 16-ports (GS116v2) / 2x NETGEAR PL1000v2
Desktop: AMD Ryzen 9 5900X - Server: Intel Core i7-7700K - NAS: Intel Pentium G4400, 20 TB
Message 2 of 7
lemick
That link will not open at all. . . Any suggestions?
Message 3 of 7
microchip8
Master
Most likely because you have a router after router (double NAT). What's the device in front of the NETGEAR router?
Message 4 of 7
@lemick wrote:
N300 WNR2000 v4
The WNR2000 doesn't connect to anything over wifi.
I'm guessing that you mean things do not connect to the router's wifi at 5 GHz.
You don't say which wifi clients you have. Some don't work at 5 GHz. That includes many IoT things.
Looking at the manual for all five routers in the WNR2000 range, I see no indication that any of them supports 5 GHz wifi. After all, it dates from 2014 based on a model launched in 2009. And the N300 wifi standard isn't 5 GHz.
Maybe that box was for a different device.
Just another user with a set of boilerplate macros.
My network DM200 -> MK93; R7800 -> GS316 -> PL1000 -> R7000P
Message 5 of 7
lemick
Well, I suspect you are correct about its age and limits, but the unit labeling matches the box exactly--and the same box says, on one end panel, N300 Wireless Router (WNR2000v4) and on the other end panel, "Simultaneous Dual Band--runs 2.4 and 5GHz bands concurrently."
The router is connected to Spectrum's internet modem and to my Windows 10 PC.
Maybe I am mis-understanding "runs 24. and 5GHz band concurrently"???
Message 6 of 7
Over the years Spectrum will have provided many different modems to customers. That may include modem/routers.The important detail is the make and model number.
You are right. The data sheet says "Simultaneous Dual Band—runs 2.4 and 5GHz bands concurrently". But the next bit says "IEEE 802.11 b/g/n 2.4 GHz". No mention of 5 GHz.
The manual doesn't even refer to 5 GHz.
Another spanner in the works is that the LAN connection is just 100BASE-Tx, so even if the router could handle 5 GHz wifi, you would not get that out of the internet.
I think not. It is just another case of bad proofreading of the documentation.
You might find this entertaining:
Solved: N300 can't find my 5G network - NETGEAR Communities
And that device is younger than yours.
Message 7 of 7
Discussion stats
  • 6 replies
  • 235 views
  • 0 kudos
  • 3 in conversation
Announcements
Orbi WiFi 7
