× Introducing the new Orbi 770 Series Mesh System. To learn more click here.
Orbi WiFi 7 RBE973
Reply
6300v2 can’t log into genie
ggopher1985
Follower
I have a notice that there is a firmware update to apply but I can’t log into genie to do anything
Message 1 of 2
Re: 6300v2 can’t log into genie
I assume that you are talking about the R6300v2.
How do I log in to my NETGEAR wireless router? | Answer | NETGEAR Support
and this:
If you cannot login to your router | Answer | NETGEAR Support
@ggopher1985 wrote:
..... I can’t log into genie to do anything
What genie is this? It could be one of several things, the browser interface, a Windows or Mac program for a PC, or a mobile Android/iThing app. Netgear labels them all as genies. Which are you using?
Manuals are always a good place to start.
Visit the support pages:
Support | NETGEAR
Feed in your model number and check the documentation for your hardware.
Check the section in the manual on updating the firmware.
Or check this:
How do I manually upgrade firmware to my NETGEAR router? | Answer | NETGEAR Support
Message 2 of 2
Top Contributors
Discussion stats
  • 1 reply
  • 818 views
  • 0 kudos
  • 2 in conversation
Announcements
Orbi 770 Series
