× Introducing the Orbi 970 Series Mesh System with WiFi 7 technology. For more information visit the NETGEAR Press Room.
Orbi WiFi 7 RBE973
Reply
AC 1200 Netgear47 router, model #R6120
MKWhite1956
I would like to know if this router is a WI FI 6 as I am looking to purchase a firestick 4K
Message 1 of 8
Accepted Solutions
Guru
Re: AC 1200 Netgear47 router, model #R6120
No, WiFi 4/5. You'll need something from NG that has RAX in the model for WiFi 6 support.
Message 2 of 8
All Replies
Guru
Message 2 of 8
MKWhite1956
Thank You
Message 3 of 8
What tells you that you need Wifi 6 to use a Firestick 4K? The ads for that say "supports Wi-Fi 6" then add:
To benefit from Wi-Fi 6, a compatible Wi-Fi 6 router, such as the eero 6+, is required. Fire TV Stick 4K is also compatible with earlier Wi-Fi routers.
The speed of your network depends as much on your Internet service than on the devices you connect to it.
Message 4 of 8
Guru
Are you looking for wifi 6 (2.4ghz/5gh) or something with 6ghz?
6ghz would be a wireless 6E device.
Message 5 of 8
Overkill. If the idea is to use a Firestick:
All-new Amazon Fire TV Stick 4K streaming device | supports Wi-Fi 6, Dolby Vision/Atmos, HDR10+ : Am...
@MKWhite1956 should read the small print.
Message 6 of 8
Guru
@plemans wrote:
@michaelkenward some versions have 6ghz.
https://developer.amazon.com/docs/fire-tv/device-specifications-fire-tv-streaming-media-player.html
https://dongknows.com/fire-tv-stick-4k-max-2nd-gen-2023-review/
Doubtless, but what does that have to do with the original question?
It seems to be that @MKWhite1956 was under the impression that Firestick 4K needs WiFi 6 to work. It doesn't.
Message 8 of 8
Discussion stats
  • 7 replies
  • 1370 views
  • 1 kudo
  • 4 in conversation
Announcements
Orbi WiFi 7
