Orbi WiFi 7 RBE973
Reply
AC-1200 Smart WiFi Router with External Antennas stops working again and again
reachchandra
Follower
Hi  , I have brought  a new router  . I have lease line connection in my office .  I have configured the router and it works well for some time , then it disconnects  from the internet  .  I tried with other netgear router, there is no disconnection  . whenever this happens i rebooted the router  and it start working again but after 10 minute or so it disconnect's . pls advice is there any problem with the router or i am missing some point  .
After configuration  , one need reboot the router again and again.
Prakash Chandra
976 330 3421
India
Model: R6220|AC1200 Smart WiFi Router with External Antennas
Message 1 of 3
Accepted Solutions
DexterJB
NETGEAR Moderator
Re: AC-1200 Smart WiFi Router with External Antennas stops working again and again
Hi @reachchandra,
Please try resetting the router to factory defaults. If the issue persists, you can try re-flashing the firmware then reset and reconfigure it again.
Dexter
Community Team
Message 2 of 3
All Replies
DexterJB
NETGEAR Moderator
Hi @reachchandra,
Dexter
Community Team
Message 2 of 3
DexterJB
NETGEAR Moderator
Hi @reachchandra,
I would like to follow up and check if you are still experiencing the issue.
Dexter
Community Team
Message 3 of 3
Top Contributors
Discussion stats
  • 2 replies
  • 3186 views
  • 0 kudos
  • 2 in conversation
Announcements
Orbi WiFi 7
