× Introducing the Orbi 970 Series Mesh System with WiFi 7 technology. For more information visit the NETGEAR Press Room.
Orbi WiFi 7 RBE973
Reply
AC1200 Smart WiFi Router(R6230)
lsgoos
Follower
Please help.  Internet provider had an outage and after the outage was fixed only one of my three connected devices will connect using my router.  I tried to forget the router on the devices and try netgear again and that did not work.  Also tried unplugging router and reconnecting but that did not work either.
Message 1 of 3
Guru
Re: AC1200 Smart WiFi Router(R6230)
what modem/gateway is the router connected to?
What firmware is on the router?
when you connect devices to the router what actual error do you get? does it say "connected, no internet". Does the wifi not broadcast at all? What actually happens
Message 2 of 3
@plemans has asked the usual key questions.
You don't say much about the rest of your network and what these devices are. But the first move after any shutdown is to restart the network in the expected order:
  • Turn off and unplug modem.
  • Turn off router and computers.
  • Plug in and turn on modem. Wait 2 minutes for it to connect.
  • Turn on the router and wait 2 minutes for it to connect.
  • Turn on computers and rest of network.
Message 3 of 3
Discussion stats
  • 2 replies
  • 450 views
  • 0 kudos
  • 3 in conversation
Announcements
Orbi WiFi 7
