× Introducing the new Orbi 770 Series Mesh System. To learn more click here.
Orbi WiFi 7 RBE973
Reply
Add device to 2.4Ghz
Guru
Re: Add device to 2.4Ghz
1. do other devices work fine? Just the wyze camera with issues?
2. you don't need to force anything. You can turn off smart connect (if that router has it) to make sure to have separate 2.4ghz/5ghz networks. Then you just make sure to connect the phone to the 2.4ghz.
Message 26 of 29
WyzeInstall
Yes, the phone and Firestick work fine on Wi-Fi, albeit 5G. Only the Wyze camera will not connect, but I can't get a 2.4Ghz connection.
I did a search for "Smart Connect" from the routers search bar and I did not anything associated with my router.
Message 27 of 29
The manual for the R6400 does not claim to support "smart connect".
Message 28 of 29
williamhoke
Tutor
To connect your Android device to a 2.4 GHz network:
Unlock your device and tap the Settings app. Tap Network & Internet > Wi-Fi. Enable Wi-Fi by tapping Use Wi-Fi at the top. Select a 2.4 GHz Wi-Fi network. ... If prompted, enter the password for the network.
Regards: https://apkholder.com/
Message 29 of 29
Top Contributors
Discussion stats
  • 28 replies
  • 3947 views
  • 1 kudo
  • 5 in conversation
Announcements
Orbi 770 Series
