Kepkey's avatar
Kepkey
Follower
Nov 29, 2020
C7000v2
Can anyone tell me where I will find the password.  I just bought the router and I am trying to set it up
  • plemans's avatar
    Password to log into the router gui or password for the wifi?
    If its to the gui, the defaults are:
    login: admin
    password: password
    the wifi ssid/password should be on the label.
    Or you can hardwire into the router via ethernet (bypassing needing the wifi password) and view/change them through the gui.
  • > Can anyone tell me where I will find the password. [...]
       You might find some relevant information in a widely neglected
    resource:
          https://en.wikipedia.org/wiki/RTFM
       Visit http://netgear.com/support , put in your model number, and look
    for Documentation.  Get the User Manual (at least).  Read.  Look first
    for "Types of logins".  Further reading might not hurt, either.
