× Introducing the Orbi 970 Series Mesh System with WiFi 7 technology. For more information visit the NETGEAR Press Room.
Orbi WiFi 7 RBE973
Reply
Can't access routerlogin.net/.com after factory reset, Model: R6200
ArtieJJ
I factory reset my R6200 and I can get the IP 192.168.1.1 via LAN plug in but oddly in the Windows network adapter screen it displays my "old" network name.  I can't access the routerlogin.net/.com page using wired or wireless.  I've factory reset it multiple times, held down the reset button while power cycling and still nothing.
The device LEDs respond as expected when factory re-setting the device.
Any help appreciated!!
Message 1 of 6
Accepted Solutions
ArtieJJ
Re: Can't access routerlogin.net/.com after factory reset, Model: R6200
Yes I am running Kaspersky.  I'll try that next.  Thanks for the feedback!!
Message 5 of 6
All Replies
TheEther
Guru
Redo the factory reset, but this time disconnect all cables except power.  Wait for the reset to complete, then connect a single computer to a LAN port.  The computer should receive an IP address in the 192.168.1.X subnet.  Try routerlogin.net or 192.168.1.1.
Message 2 of 6
ArtieJJ
This didn't work either.  I still got DHCP 192.168.1.1, I can ping it, but can't access either the IP or routerlogin.com/.net.
Message 3 of 6
TheEther
Guru
You wouldn't happen to have Kaspersky Antivirus installed?  For some reason, it simply doesn't like routers.  You may have to temporarily uninstall it, or try the suggestion in this Netgear article (link).
Message 4 of 6
ArtieJJ
Message 5 of 6
ArtieJJ
Kaspersky was the issue but only after I installed the most recent NetGear firmware upgrade.  Thanks!!!!
Message 6 of 6
Top Contributors
Discussion stats
  • 5 replies
  • 3195 views
  • 0 kudos
  • 2 in conversation
Announcements
Orbi WiFi 7
