sinergyinaction
Sep 14, 2022Aspirant
Can't login the router interface N600 WNDR3400 v3
Hi,
I trying to use my old N600 WNDR3400 v3 router again after a lapse of time (2019 was the last time I used it)
and I can't login the router interface. I am asked a password and when I insert it it doesn't accept it.
I reset the router to its default configuration, using the accreditation data on the back of the router itself, and still the indicated password isn't accepted
I actually did the reset a couple of times already.
I also tried from a lan port to access the router, to no avail.
What else can I try?
Regards
1 Reply
What else is on the network that you are using to get at this thing?
If there is another router there, they may start arguing over which is in charge.
Try getting into it from something that is not on the network.
