× Introducing the Orbi 970 Series Mesh System with WiFi 7 technology. For more information visit the NETGEAR Press Room.
Orbi WiFi 7 RBE973
Reply
Cannot establish wifi signal on Netgear extender to Fios router
stpham168
Follower
 Following the Netgear instructions to connect the NetGear extender to the new router Verizon Fios WiFi 6 but failed after may attempts (5 times). No LED  appeared on the Link status on the NetGear Extender. What should I do to have they connected? The new router has no "WPS" button to sync with NetGear Extender! Can some one gives me guidance. Thank you.
SonPham
Model: EX8000|AC3000 Nighthawk X6S Tri Band WiFi Mesh Extender
Message 1 of 2
Guru
Re: Cannot establish wifi signal on Netgear extender to Fios router
Which fios router is it?
Are you using the installation assistant on the EX8000?
where is it failing in the process?
Current setup: CM2000-> RBKE963B-> Trendnet TEG-S380-> GS716T-> pi-hole
also in AP setup: RAXE500->EAX80
1.4gig download/50mbps upload from Xfinity
We’re members of the public helping out on our own time.
Message 2 of 2
Discussion stats
  • 1 reply
  • 409 views
  • 0 kudos
  • 2 in conversation
Announcements
Orbi WiFi 7
