- Subscribe to RSS Feed
- Mark Topic as New
- Mark Topic as Read
- Bookmark
- Subscribe
- Printer Friendly Page
Difficulty setting up WNR2000 v2 as repeater with Mofi4500
- Mark as New
- Bookmark
- Subscribe
- Permalink
I've been trying to setup my WNR2000 v2 as a repeater against my Mofi4500 Base Station following the instructions listed in the Manual
1. I change the LAN IP to something within my Base Station range. In my case I set the Repeaters LAN to 192.168.10.10. since my Base Station is 192.168.10.1.
2. Under Wireless Settings I set the SSID to the same as my Base Station. There is no security on the Base Station so I set the same on the Repeater.
3. Under Wireless Repeating Function screen, I select the Enable Wireless Repeater Mode radio and set the IP address of the Repeater (192.168.10.10) and MAC Adderess of the Base Station and Save.
WIth all those settings applied I can connect to the Netgear Repeater but I'm not getting assigned a valid IP from the Base Station, just a self-configured 169.... address. If I manually set me IP address and subnet and set my Router as 192.168.10.10 (the repeater's IP), I can get back into the Netgear. Under Router Status -> Wireless Repeating is shows the Link Rate and Signal Strength as "disconnected".
So I'm not getting the Netgear to connect to the Mofi and hand out valid IP for access. Any ideas what else I would need to change on the Netgear repeater or on the Mofi base station?
