- Subscribe to RSS Feed
- Mark Topic as New
- Mark Topic as Read
- Bookmark
- Subscribe
- Printer Friendly Page
EX6110 (4XX69BD7A089C)
- Mark as New
- Bookmark
- Subscribe
- Permalink
When i try to connect with a chrome book, it works for a few days and they says that i need to visit their website.
It shoudl be simple, plug it in, set it up and it should just work. Am i missing something or does anyoen else have to visit the website but their is no solution on the website to fix. The only way i can get it to work is to reset it and start it from the beginning.
- Mark as New
- Bookmark
- Subscribe
- Permalink
Re: EX6110 (4XX69BD7A089C)
What router are you connecting it to?
Did you install it using wps or using the installation assistant?
I'd highly recommend the assistant. wps doesn't alway get coded the same and create issues. its why the installation assistant is there.
