Stallion69
Nov 23, 2020Tutor
Enabling Daisy Chain Topology
I currently have Orbi RBR50 ROuter with 2 RBS50 Satellitles. I connected the two satellites directly to the Orbi router with ether net cables. In other words, I made a star connection with ethernet cables. In the Orbi Settings, under the "Advanced Wireless Settings" I have the "Enable Dasiy-Chain Topology" checked. I thought Daisy Chain is when a Satellite communicates with another satellite which then communicates with the router? In my case, since i wired both satellites directly to the Router, do I Dis-Able the Daisy-Chain Topology?" Advice is greatly appreciated
| Backhaul Topology |
| Enable Daisy-Chain Topology |
1 Reply
> [...] I thought Daisy Chain is when a Satellite communicates with
> another satellite which then communicates with the router? [...]Visit http://netgear.com/support , put in your model number, and look
for Documentation. Get the User Manual. Read. Look for "Daisy".> [...] In my case, since i wired both satellites directly to the
> Router, do I Dis-Able the Daisy-Chain Topology?"You can leave it enabled, and not actually use it. I know nothing,
but I'd expect it to be harmless.
