× Introducing the new Orbi 770 Series Mesh System. To learn more click here.
Orbi WiFi 7 RBE973
Reply
Having Random Latency
Marvin_T
Tutor
Hello, Ive been having issues with gaming while gaming on my Netgear CM600. My latency variation is high and it causes a bit of rubber banding in online first person shooters. I have tried using the CM600 without a router and with a router that contains anti buffer bloat software. After doing a lot of research and purchasing new routers and talking with my ISP (Spectrum) to no avail, I have come to the conclusion that it must be my modem. I logged into my modem recently and found that I was getting a lot of sync timing synchronization failures and read that this could be causing my issues with latency. How would I fix this? Below are all my readings for my modem. Note: there is a splitter in my wall panel where the coax comes from outside and I have tried removing it and latency issue remains.
Time Priority Description
2022-08-21, 22:35:07 Error (4) Missing BP Configuration Setting TLV Type: 17.8;CM-MAC=38:94:ed:d6:e6:d0;CMTS-MAC=00:17:10:88:a4:9a;CM-QOS=1.1;CM-VER=3.0;
2022-08-21, 22:35:07 Error (4) Missing BP Configuration Setting TLV Type: 17.9;CM-MAC=38:94:ed:d6:e6:d0;CMTS-MAC=00:17:10:88:a4:9a;CM-QOS=1.1;CM-VER=3.0;
2022-08-04, 21:36:14 Critical (3) Resetting the cable modem due to docsDevResetNow
2022-08-04, 21:07:27 Critical (3) Resetting the cable modem due to docsDevResetNow
2022-08-03, 23:54:41 Critical (3) No Ranging Response received - T3 time-out;CM-MAC=38:94:ed:d6:e6:d0;CMTS-MAC=00:17:10:88:a4:9a;CM-QOS=1.0;CM-VER=3.0;
2022-08-03, 23:52:34 Critical (3) No Ranging Response received - T3 time-out;CM-MAC=38:94:ed:d6:e6:d0;CMTS-MAC=00:17:10:88:a4:9a;CM-QOS=1.0;CM-VER=3.0;
Time Not Established Critical (3) No Ranging Response received - T3 time-out;CM-MAC=38:94:ed:d6:e6:d0;CMTS-MAC=00:17:10:88:a4:9a;CM-QOS=1.0;CM-VER=3.0;
Time Not Established Critical (3) Ranging Request Retries exhausted;CM-MAC=38:94:ed:d6:e6:d0;CMTS-MAC=00:17:10:88:a4:9a;CM-QOS=1.0;CM-VER=3.0;
Time Not Established Critical (3) SYNC Timing Synchronization failure - Failed to acquire QAM/QPSK symbol timing;CM-MAC=38:94:ed:d6:e6:d0;CMTS-MAC=00:00:00:00:00:00;CM-QOS=1.0;CM-VER=3.0;
Time Not Established Critical (3) SYNC Timing Synchronization failure - Failed to acquire FEC framing;CM-MAC=38:94:ed:d6:e6:d0;CMTS-MAC=00:00:00:00:00:00;CM-QOS=1.0;CM-VER=3.0;
Time Not Established Notice (6) Overriding MDD IP initialization parameters; IP provisioning mode = IPv6
Startup Procedure
Procedure Status Comment
Acquire Downstream Channel 357000000 Hz Locked
Connectivity State OK Operational
Boot State OK Operational
Security Enable BPI+
IP Provisioning Mode Override MDD IPv6 only
Downstream Bonded Channels
Channel Lock Status Modulation Channel ID Frequency Power SNR Correctables Uncorrectables
1 Locked QAM256 11 357000000 Hz -1.2 dBmV 41.4 dB 0 0
2 Locked QAM256 2 303000000 Hz -0.3 dBmV 42.4 dB 0 0
3 Locked QAM256 3 309000000 Hz -0.5 dBmV 42.2 dB 0 0
4 Locked QAM256 31 489000000 Hz -2.6 dBmV 40.1 dB 0 0
5 Locked QAM256 5 321000000 Hz -0.9 dBmV 41.8 dB 0 0
6 Locked QAM256 18 399000000 Hz -1.9 dBmV 40.5 dB 0 0
7 Locked QAM256 7 333000000 Hz -1.4 dBmV 41.3 dB 0 0
8 Locked QAM256 8 339000000 Hz -1.6 dBmV 40.9 dB 0 0
9 Locked QAM256 9 345000000 Hz -1.3 dBmV 41.1 dB 0 0
10 Locked QAM256 10 351000000 Hz -1.6 dBmV 41.0 dB 0 0
11 Locked QAM256 1 297000000 Hz -0.6 dBmV 42.0 dB 0 0
12 Locked QAM256 12 363000000 Hz -1.6 dBmV 40.9 dB 0 0
13 Locked QAM256 13 369000000 Hz -1.2 dBmV 41.2 dB 0 0
14 Locked QAM256 14 375000000 Hz -1.2 dBmV 41.3 dB 0 0
15 Locked QAM256 15 381000000 Hz -1.8 dBmV 40.6 dB 0 0
16 Locked QAM256 16 387000000 Hz -1.4 dBmV 41.1 dB 0 0
17 Locked QAM256 17 393000000 Hz -2.2 dBmV 40.7 dB 0 0
18 Locked QAM256 29 477000000 Hz -2.9 dBmV 39.9 dB 0 0
19 Locked QAM256 19 405000000 Hz -2.0 dBmV 40.8 dB 0 0
20 Locked QAM256 20 411000000 Hz -1.7 dBmV 40.8 dB 0 0
21 Locked QAM256 21 423000000 Hz -1.7 dBmV 40.8 dB 0 0
22 Locked QAM256 22 429000000 Hz -1.1 dBmV 41.4 dB 0 0
23 Locked QAM256 23 435000000 Hz -2.1 dBmV 40.8 dB 0 0
24 Locked QAM256 24 447000000 Hz -1.9 dBmV 40.8 dB 0 0
Upstream Bonded Channels
Channel Lock Status US Channel Type Channel ID Symbol Rate Frequency Power
1 Locked ATDMA 3 5120 Ksym/sec 30400000 Hz 48.0 dBmV
2 Locked ATDMA 4 5120 Ksym/sec 36800000 Hz 49.3 dBmV
3 Not Locked Unknown 0 0 Ksym/sec 0 Hz 0.0 dBmV
4 Not Locked Unknown 0 0 Ksym/sec 0 Hz 0.0 dBmV
5 Not Locked Unknown 0 0 Ksym/sec 0 Hz 0.0 dBmV
6 Not Locked Unknown 0 0 Ksym/sec 0 Hz 0.0 dBmV
7 Not Locked Unknown 0 0 Ksym/sec 0 Hz 0.0 dBmV
8 Not Locked Unknown 0 0 Ksym/sec 0 Hz 0.0 dBmV
Message 1 of 5
Accepted Solutions
Marvin_T
Tutor
Re: Having Random Latency
Hello, the issue was due to something on the ISP side. After scheduling a tech visit, the next day I received a text that my service had been restored before the tech had even come. So after doing some testing there were no more latency issues. I’m not sure what they did but it seemed to work. Thank you all! Happy Gaming!
Message 4 of 5
All Replies
Guru
Start with removing any amplifiers, signal attenuators, or splitters from the coax.
From there check the line for kinks, damage, moisture in the line.
Check the connectors for improperly made ends, foil touching the copper coax line, bad/old/cheap connectors, or corroded connections. Replace them if you do.
If you can, simply connect the modem right where the coax comes into the home. This prevents wiring in the home from being the issue. And some ISP’s charge if the wiring issue is in the home. So this helps prevent this.
Seems like theres issues with the line to the point the cmts is sending reboot signals
Message 2 of 5
Marvin_T
Tutor
Will do! I will assemble and plug in modem where it comes it at my home. I’m sorry I forgot to mention in the original post that it was me that initiated those documented resets in the event log. I will return within 48 hours with an update and documented results. Thanks for your assistance in advance!
Message 3 of 5
Marvin_T
Tutor
Message 4 of 5
Guru
Glad you got it fixed!
You might mark it solved so others aren't still trying to fix it 🙂
Message 5 of 5
Top Contributors
Discussion stats
  • 4 replies
  • 2788 views
  • 1 kudo
  • 2 in conversation
Announcements
Orbi 770 Series
