Orbi WiFi 7 RBE973
Reply
How much data transfer speed should I expect from Netgear r6400v2 using SSD on usb 3.0 ?
Kuttoosssan
Router - R6400v2
SSD - Samsung T5 500GB
Cable - Cat 6
How much speed should I get while transferring from PC to SSD via Ethernet?
This is what I get on LAN Speed test, (attached photo)
On actual movie file transfer test also, I get maximum 24MB/s only.
Is this a limitation of the router?
Model: R6400|AC1750 Smart WiFi Router
Message 1 of 4
Accepted Solutions
Guru
Re: How much data transfer speed should I expect from Netgear r6400v2 using SSD on usb 3.0 ?
@Kuttoosssan wrote:
Thank you for the reply.
Is this because the actual router capacity is limited?
Or is it a firmware limitation?
It tends to be a hardware limit. When you start needing faster speeds, you need the hardware designed to run it and not a router with the included funcationality.
Message 4 of 4
All Replies
Guru
a lot depends on file type/size/format. But you're speed look roughly in line with what smallnetbuilder got when testing usb speeds.
https://www.smallnetbuilder.com/wireless/wireless-reviews/32812-netgear-r6400-ac1750-smart-wifi-rout...
If you're needing faster speeds, its better to actually invest in an actual NAS device or server.
Message 2 of 4
Kuttoosssan
Message 3 of 4
Guru
Message 4 of 4
Top Contributors
Discussion stats
  • 3 replies
  • 1339 views
  • 2 kudos
  • 2 in conversation
Announcements
Orbi WiFi 7
