Orbi WiFi 7 RBE973
Reply
How to setup Netgear AC600
Theo74
Follower
I have successfully registered my Netgear AC600 but do not know how to proceed in the set up process. Please help
Message 1 of 3
Guru
Re: How to setup Netgear AC600
You gave us nothing to go off.
There's a support site with access to manuals, firmware, install guides, etc.
Go to https://www.netgear.com/support/
Type in your model number and from there it'll take you to the above.
Its a great resource to start with.
Message 2 of 3
AC600 is not a reliable guide to model number. Many devices come with an AC tag, but it is essentially a label that Netgear, and other brands, attach to hardware to describe wifi speeds.
Look at the label on the device for the model number.
Then check the support pages for that device. That will usually reveal a Quick Start guide that tells you how to set it up.
Message 3 of 3
Top Contributors
Discussion stats
  • 2 replies
  • 728 views
  • 0 kudos
  • 3 in conversation
Announcements
Orbi WiFi 7
