× Introducing the Orbi 970 Series Mesh System with WiFi 7 technology. For more information visit the NETGEAR Press Room.
Orbi WiFi 7 RBE973
Reply
How to turn wireless on using phone after a reset on wgr614 v7
Gperez425
Follower
I reset a netgear wgr614 v7 and now the wireless won't turn on to configure using my phone. How do I turn it on to configure through my phone?
Message 1 of 3
Accepted Solutions
DexterJB
NETGEAR Moderator
Re: How to turn wireless on using phone after a reset on wgr614 v7
Hi @Gperez425,
Welcome to the community!
1. Are you referring to the wireless LED indicator on the front panel of the router?
2. You can try accessing the router UI and make sure the settings are configured correctly. The setup manual is linked below.
http://www.downloads.netgear.com/files/GDC/WGR614V7/wgr614v7_setup_manual_21apr06.pdf?cid=community
Dexter
Community Team
Message 2 of 3
All Replies
DexterJB
NETGEAR Moderator
Hi @Gperez425,
Dexter
Community Team
Message 2 of 3
DexterJB
NETGEAR Moderator
Hi @Gperez425,
I would like to follow up and check if you are still experiencing the issue.
Dexter
Community Team
Message 3 of 3
Top Contributors
Discussion stats
  • 2 replies
  • 999 views
  • 0 kudos
  • 2 in conversation
Announcements
Orbi WiFi 7
