× Introducing the new Orbi 770 Series Mesh System. To learn more click here.
Orbi WiFi 7 RBE973
Reply
I TURNED ON MY ROUTER TODAY TO HOOK UP AND LIGHT COMES ON GREEN AND TURNS AMBER ? RBR50
SAMIBELLA
Follower
TURNED ON ROUTER TO SET UP LIGHT TURNS GREEN AND THEN AMBER I CANT RESET IT NOTHING WORKS?   ITS A RBR50  A YEAR OLD I HAD IT SET UO USED FOR A WEEK WORKED FINE..
Message 1 of 2
Guru
Re: I TURNED ON MY ROUTER TODAY TO HOOK UP AND LIGHT COMES ON GREEN AND TURNS AMBER ? RBR50
1. Caps lock. Please un-click it
2. what led are we talking about? The power one?
3. did you try a factory reset? Push and hold reset for 7-15 seconds while its powered on?
4.You can try recovering it with tftp or nmrpflash.
are you on windows? if so, follow this guide
https://kb.netgear.com/000059634/How-to-upload-firmware-to-a-NETGEAR-router-using-Windows-TFTP
just make sure you enable tftp
https://www.thewindowsclub.com/enable-tftp-windows-10
and here's a video walk through using a tftp client. Use the built in one for windows 10 though. the video is more of an example of how its done.
https://www.youtube.com/watch?v=R9DLrLQrpaw
and if that doesn't work, you can try using nmrpflash
https://github.com/jclehner/nmrpflash
Message 2 of 2
Top Contributors
Discussion stats
  • 1 reply
  • 413 views
  • 0 kudos
  • 2 in conversation
Announcements
Orbi 770 Series
