jeffr3yapp1et0n's avatar
Dec 28, 2023
I tried starting tftpd with the router connected, and it says the machine actively refused it
  • michaelkenward's avatar
    michaelkenward
    Does that have anything to do with this discussion?
    You have joined in on an existing conversation from 2021 that may or may not have anything to do with your problems.
    There is also a good chance that the official support team is busily monitoring new conversations and may miss your addition to this one.
    If you do want help with your problem, check previous stuff that may be related then start your own discussion.
    If you do decide to ask a question, you should provide more details and your own version of the information that the forum suggests that you provide. For example, as this is a router, it helps to know what modem you are using and the various things that you have tried to fix the problem.
    By the way the R6080, a seven year iod model, is very low spec.
    According to Netgear's manual for this device, not always the most reliable source of information, the LAN and WAN ports support only 10BASE-T or 100BASE-TX. That makes it slower than many newer internet services and most modern network hardware. This may not matter to you, but be warned that it will hobble you if you ever sign up for faster Internet, anything faster than 100 Mbps is a waste of your money.
    • jeffr3yapp1et0n's avatar
      jeffr3yapp1et0n
      It is not my router primarily. I found it at a salvation army store for 2.99, and thought it would be a good buy.
  • FURRYe38's avatar
    Try a 30-30-30 reset on the router with out anything connected to it.
