× Introducing the new Orbi 770 Series Mesh System. To learn more click here.
Orbi WiFi 7 RBE973
Reply
Increase Ethernet Output speed on Netgear R6220 router
azcowboy
I am having trouble obtaining the same (or nearly the same) ethernet output speed from my router as I obtain directly from my modem.
I have tested my Cisco Modem (using speakeasy) wired directly to my PC and it outputs download speeds of approx 114 Mbps.
When I run the same speed test on my ethernet netwwork, I only obtain about 40Mbps ethernet output from the router, .
The ethernet  network consists of 2 PC's, 1 Printer, and an ethernet connection to a wireless transmission for my Solar panel system, It also has wireless streaming to a TV (via Roku).
How may I obtain at least 80Mbps ethernet output with 113Mbps input on my Netgear R6220 router?
I am using a Netgear R6220 AC1200 Smart WiFi Router with external antennas
My cableing is Cat5 and Cat5e
Thank you in advance for any assistance
Larry Goldberg
Message 1 of 3
Accepted Solutions
azcowboy
Re: Increase Ethernet Output speed on Netgear R6220 router
I replaced the CAT5 and CAT5E cables with CAT6a (Shielded Twisted pair) and my problem is solved.  Spedd went from 40Mbps to 160+Mbps on the ethernet connection.
Many thanks,
AZ Cowboy
Message 3 of 3
All Replies
netwrks
Master
Remove any CAT5 cables you are using from your network, and replace with at least CAT5e cables, and try agian.
Message 2 of 3
azcowboy
Many thanks,
AZ Cowboy
Message 3 of 3
Discussion stats
  • 2 replies
  • 3845 views
  • 0 kudos
  • 2 in conversation
Announcements
Orbi 770 Series
