× Attn: Nighthawk Pro Gaming members, we have recently released firmware to address a critical security vulnerability. For more information click here. .
Orbi WiFi 7 RBE973
Reply
Intermittent wifi issue (Model C3000)
Muthanna
Follower
Hi ,
We are facing intermittent wifi connection issue.
Note : Network (Comcast) technician told that its issue with the router. need to update the router frame. Please help to take it forward.
Model :  N300 Wi-Fi DOCSIS 3.0 Cable Modem Router (C3000)
Model: C3000|N300 Cable Gateway Docsis 3.0
Message 1 of 2
Guru
Re: Intermittent wifi issue (Model C3000)
Only the wifi is having issues?
Wired devices work fine?
What actual issues are you having? A detailed description of whats happening/going on helps more than "intermittent wifi issue"
Also, the C3000 is a single band 2.4ghz device. 2.4ghz is more sensitive to interference and its slow. If you live in an apartment/condo/residence with a lot of signals, you will likely fact connection issues because the 2.4ghz bandwidth gets over crowded in those locations.
Message 2 of 2
Discussion stats
  • 1 reply
  • 660 views
  • 0 kudos
  • 2 in conversation
Announcements
Orbi 770 Series
