× Introducing the new Orbi 770 Series Mesh System. To learn more click here.
Orbi WiFi 7 RBE973
Reply
MY RBK 50V2 - AC3000 Tri-band
Edwarmr
Follower
RBK 50V2 - MOST OF THE DEVICES WILL NOT CONNECT TO THE ROUTER BUT IT'S SHOWING NORMAL SPEED TEST. I HAD THE MODEM CHECKED AND IT'S WORKING PROPERLY. WHEN I CONNECTED TO THE ROUTER ETHER PORT, THE ROUTER SPEED TEST WAS A LOT LOWER THAN WHEN I WAS JUST CHECKING WIFI.
Message 1 of 2
Guru
Re: MY RBK 50V2 - AC3000 Tri-band
A couple things.
1. Caps  lock. Please disable it. Its makes reading your posts a pain/annoyance when they're all in caps.
2. firmware. What firmware is on the orbi?
3. gateway. What modem/gateway is the orbi connected to?
4. when you say "most of the devices will not connect" what actually happens. Can they not see the ssid? Do they not connect? Do they connect but say "connected, no internet".  What actually is going on? Details are needed since we aren't there to see whats going on
5. What speeds do you get hardwired into the router? And over 2.4ghz? And over 5ghz?
Message 2 of 2
Top Contributors
Discussion stats
  • 1 reply
  • 625 views
  • 0 kudos
  • 2 in conversation
Announcements
Orbi 770 Series
