× Introducing the Orbi 970 Series Mesh System with WiFi 7 technology. For more information visit the NETGEAR Press Room.
Orbi WiFi 7 RBE973
Reply
N-300 Setup
JayPoppe
N-300 Setup
I have an old N-300 WNR2000-v2 router that I'm trying to setup.  I recently had to reset to factory settings.  Now when running the setup application, it bombs when trying to load the Adobe Flash Player software.  I have since learned that Flash Player is no longer supported by Adobe.  Does Netgear have a new setup app for this router?  Is there a work around?  Is my router now useless?
Message 1 of 3
wcalifas
Prodigy
Re: N-300 Setup
you don't need adobe to do the setup for the router. Just use mozilla, microsoft edge or chrome browser. Just type www.routerlogin.net or 192.168.1.1. admin for admin and password for password. You'll have to set up the wifi password and whatever you want your wifi to be named.
Message 2 of 3
JayPoppe
Re: N-300 Setup
Thanks I'll try it out.
Message 3 of 3
Discussion stats
  • 2 replies
  • 462 views
  • 0 kudos
  • 2 in conversation
Announcements
Orbi WiFi 7
