× Introducing the new Orbi 770 Series Mesh System. To learn more click here.
Orbi WiFi 7 RBE973
Reply
N300 not connecting
Mobrien31
Follower
N300 not connecting
Hi, i have had this range Extender for a quite a few years but not used it in a longtime. I'm trying to connect it to a new router that has no wps. I had to use an ether net cable to get it to even pick the router up.
However, when I try to use the WiFi ext.net to set it up, I keep getting a message stating "reset (1)". Or on a computer it just says I am not connected to the Internet. Anyone know what I could do?
Model: EX2700|N300 WiFi Range Extender Essentials Edition
Message 1 of 2
Guru
Re: N300 not connecting
You shouldn't be running the cable from the router to the EX2700. Reason why is that'd be running it in access point mode and the EX2700 doesn't have access point mode.
Try factory resetting it. Push and hold reset for 7-15 seconds while its powered on. Then try installing using the installation assistant.
the 2nd video on the support site shows how to use the assistant.
https://www.netgear.com/support/product/EX2700.aspx
Message 2 of 2
Top Contributors
Discussion stats
  • 1 reply
  • 471 views
  • 0 kudos
  • 2 in conversation
Announcements
Orbi 770 Series
