× Introducing the Orbi 970 Series Mesh System with WiFi 7 technology. For more information visit the NETGEAR Press Room.
Orbi WiFi 7 RBE973
Reply
N600 - Can't find Access List after firmware upgrade
Reb1
I just upgraded my N600 to V1.0.0.52_1.0.81 and I can no longer get to my Access List to edit/add a MAC address. There used to be a button for it at the bottom of Advaced>Advanced Setup>Wireless Settings, but it's not there now. I can see my list of devices in Advanced>Security>Access Control, but I don't see a way to get to my list to make any changes. Where did it go?
Model: WNDR3400v2|N600 Wireless Dual Band Router
Message 1 of 4
Accepted Solutions
ElaineM
NETGEAR Employee Retired
Re: N600 - Can't find Access List after firmware upgrade
Hi @Reb1
Welcome to the community!
What are the changes you need to do?
It's either you delete or add by clicking the dropdown arrow that says "View list of allowed devices..."
If you want to change the device name then delete it first then add it again using the desired device name.
Message 2 of 4
All Replies
ElaineM
Hi @Reb1
Message 2 of 4
Reb1
Hi Elaine,
Thanks for the reply. I can't say I'm liking this deviation from a normal ACL. It looks like my old ACL is gone and I'm going to have to add some devices back in. It's also not very user friendly to have to delete a device if I want to change the name, as I'll have to put the MAC address back in, too. I wish I hadn't updated the firmware, and I may even consider rolling it back. But thanks for telling me how this new system works.
Message 3 of 4
ElaineM
@Reb1 Forwarded that feedback to the management.
Message 4 of 4
Top Contributors
Discussion stats
  • 3 replies
  • 2353 views
  • 0 kudos
  • 2 in conversation
Announcements
Orbi WiFi 7
