- Subscribe to RSS Feed
- Mark Topic as New
- Mark Topic as Read
- Bookmark
- Subscribe
- Printer Friendly Page
N600 won't go over 50mbps
- Mark as New
- Bookmark
- Subscribe
- Permalink
Solved! Go to Solution.
Accepted Solutions
- Mark as New
- Bookmark
- Subscribe
- Permalink
The netgear r6400 or better depending how big your home is and how much you want to pay the r6400 is ac1750 router 400 mbis on 2.4 ghz n band and 1.3ghz ac on the 5 ghz band for around the 150 dollar or below mark no need for r8500 unless you have need of its power.
All Replies
- Mark as New
- Bookmark
- Subscribe
- Permalink
Re: N600 won't go over 50mbps
Are you getting these results with a wired or a wireless device? If wireless, are you testing at 2.4 GHz or 5 GHz? What kind of device is it? Provide the model number and/or Wi-Fi specs, if possible.
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Mark as New
- Bookmark
- Subscribe
- Permalink
That's good for the wndr3400 with it's 100mbit lan ports and less then 500mhz signle core processor 50mbits and limit to 150 and 300 mbits for 2.4 and 5 ghz channels which you would lucky to reach max speeds. I have 72.6 mbits on my wired ports and only about low 30's to mid 40's and the 5ghz band is dead.
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Mark as New
- Bookmark
- Subscribe
- Permalink
