× Introducing the Orbi 970 Series Mesh System with WiFi 7 technology. For more information visit the NETGEAR Press Room.
Orbi WiFi 7 RBE973
Reply
Netgear R6400 Slow Wired Speed Issues
BigNutBean
Good afternoon folks, I'm new to the forums and new to home networking in general. I tried searching the forums and online for solutions but I got mixed results and I'm not sure how to proceed forward.
Problem: I'm not getting the advertised speed from my ISP while using my router. Conducting a speed test, I only get a maximum of 95 Mbps upload and download. Connecting directly to my Modem, I get the full advertised speed both for my Laptop and PC.
I have tried doing a factory reset on the Router and then updating its firmware to the latest version but it still shows 95 Mbps up and down. I made sure in the Nighthawk App that Traffic Meter is turned off. I logged into my Router and went into Advance Settings and made sure that Upstream and Downstream QoS in turned off/unchecked.
ISP Plan: Symmetrical internet 600/600 Mbps
Modem: Nokia ONT XS-010X-Q
Router: R6400
Router Firmware: V1.0.1.78_1.0.50
Thank you!
Note: All test were performed using a WIRED connection unless stated otherwise.
Message 1 of 5
Re: Netgear R6400 Slow Wired Speed Issues
The first refrain you will here is "Check the cables".
Message 2 of 5
Guru
You can check and see what link speed its connecting at
https://kb.netgear.com/24222/How-do-I-display-Internet-port-statistics-on-my-Nighthawk-router
if its 10/100mbps, then try swapping cables
Message 3 of 5
BigNutBean
Hello! I have checked my cables and ran them through a speed test and everything came out looking normal except when plugged into the R6400 Router as pictured below. I do not get my full speed.
 _______________________________________________________________________________________________
When I ran the test as pictured below, I get my full internet speed.
I followed your instruction on checking the link speed and it shows 10/100mbps at the WAN Port. I unfortunately do not have another ethernet cable and will have to wait for another cable to arrive to test. What I don't understand is if I'm getting full speed connecting directly to the Modem, my cables should be fine and eliminated as the suspect?
Thank you!
Message 4 of 5
Guru
some devices aren't as tolerant as others of sketcy connections. Routers tend to be less tolerant as if they mess up, the whole system messes up. Versus if a laptops connection is sketchy, its only effecting itself.
but it could be the router. That's always a chance. A bent/dirty, or bad port could be causing it. I'm not ruling that out.
Message 5 of 5
Top Contributors
Discussion stats
  • 4 replies
  • 340 views
  • 0 kudos
  • 3 in conversation
Announcements
Orbi WiFi 7
