× Introducing the Orbi 970 Series Mesh System with WiFi 7 technology. For more information visit the NETGEAR Press Room.
Orbi WiFi 7 RBE973
Reply
Netgear WNDR3400 V2 dashboard
barsim2
Follower
Hello,
Unable to get into my rourter dashbord because some time ago i changed the manufacturer credentials (admin and password) to something different that i didn't keep.
Is there any way to overcome this quandary?
Thank you
Message 1 of 4
Accepted Solutions
Re: Netgear WNDR3400 V2 dashboard
@barsim2 wrote:
.... some time ago i changed the manufacturer credentials (admin and password) to something different that i didn't keep.
The only thing that you could change would have been the password. The "admin" bit is fixed.
Message 3 of 4
All Replies
Guru
Not sure if password recovery works on that old of a device but you can try.
https://kb.netgear.com/24220/How-do-I-recover-my-NETGEAR-admin-password-using-the-password-recovery-...
If not, you can always factory reset it to get back to the defaults and then just reinstall it
Message 2 of 4
Message 3 of 4
wcalifas
Prodigy
You can always do a hard reset and it will go back to factory default and you'll have to do your settings over again that you might have had saved already.
Message 4 of 4
Top Contributors
Discussion stats
  • 3 replies
  • 1257 views
  • 0 kudos
  • 4 in conversation
Announcements
Orbi WiFi 7
