× Introducing the Orbi 970 Series Mesh System with WiFi 7 technology. For more information visit the NETGEAR Press Room.
Orbi WiFi 7 RBE973
Reply
Netgear WNR2000 router drops connection to server
Suzyelle
Initiate
I have a WNR2000 and I'm having a problem. Some sites connect to the server, and some do not. Google mail doesn't connect from ipad, iphone or Kindle. Ironically, Microsoft communities won't ususally connect. This since windows 10 update.
Message 1 of 3
Accepted Solutions
Suzyelle
Initiate
Re: Netgear WNR2000 router drops connection to server
I updated the firmware. That solved the problem.
Message 3 of 3
All Replies
ElaineM
NETGEAR Employee Retired
Welcome to the community, @Suzyelle
What's the exact model version of your router?
The model version is found on the actual device. See this link.
Are you confirming that this problem did not occur prior to upgrading the Windows computer to Windows 10?
One thing to try is to adjust the MTU on the router.
Set the MTU to 1400. Check this article for similar steps on how to adjust the MTU.
Let us know what happens.
Message 2 of 3
Suzyelle
Initiate
Message 3 of 3
Top Contributors
Discussion stats
  • 2 replies
  • 3657 views
  • 1 kudo
  • 2 in conversation
Announcements
Orbi WiFi 7
