× Introducing the Orbi 970 Series Mesh System with WiFi 7 technology. For more information visit the NETGEAR Press Room.
Orbi WiFi 7 RBE973
Reply
Nighthawk R7960P Preventing intranet services (SSH, Bounjour, dropping packets)
camjones1708
My setup is the Nighthawk R7960P sitting behind the AT&T provided all-in-one modem with the wi-fi turned off. The nighthawk is connected with its WAN to the LAN of the AT&T router. My reasoning for this is for QOS enabled on the nighthawk so I can game while others stream in the house.
The issue I am experiencing is that services that bind to specific ports are being blocked internally in the network. I have confirmed IP addresses multiple times. SSH was one that would not work from any machine to my raspberry pi. The other service is bonjour for our canon printer. Neither my macbook nor my windows desktop could connect to the printer. Additionally, I was receving a lot of packet loss while playing call of duty.
I have tried:
- Rebooting all devices
- Reverting firmware on the nighthawk.
- Looking for blocked ports/services ( none found)
I got around this by taking out the nighthawk router and enabling wi-fi on the AT&T device. This resolved both issues.
Is there a setting on the nighthawk that I am missing causing these issues?
Model: R7900P|Nighthawk X6S AC3000 Tri Band WiFi Router
Message 1 of 31
Accepted Solutions
schumaku
Guru
Re: Nighthawk R7960P Preventing intranet services (SSH, Bounjour, dropping packets)
The effect you are fighting ref. your RasPi and the random access does very well indicate there are multiple devices with the same IP address ou your network (LAN and WLAN).
Leaving the names alone (no clue what Netgear is riding since they have added this attached device detection): Are the systems on the network with fixed IP addresses? If all devices are DHCP, has everything be cold booted, starting with the router? Check the view with each device coming back to the network, review each device config, ...
Message 30 of 31
All Replies
Guru
Disabling wifi doesn't disable the routing function of the att device.
It leaves you in a double nat with 2 routers in router mode on the network.
https://kb.netgear.com/30186/What-is-Double-NAT
options? (only use 1)
1. put the att combo device in passthrough modem only mode. Again, disabling the wifi doesn't do this
2. put the netgears IP address into the att devices dmz.
3. put the netgear in access point mode.
What speeds do you pay for with att?
If its >250mbps, qos isn't recommended as it can actually hurt speeds versus help them.
Current setup: CM2000-> RBKE963B-> Trendnet TEG-S380-> GS716T-> pi-hole
also in AP setup: RAXE500->EAX80
1.4gig download/50mbps upload from Xfinity
We’re members of the public helping out on our own time.
Message 2 of 31
camjones1708
Thanks for the quick reply.
BGW320-500 is the AT&T listed modem. I found an article on placing that into passhtrough mode. https://www.att.com/support/smallbusiness/article/smb-internet/KM1188700
I've got gigabit speeds. I enabled QOS because I was getting latency issues (150ms+) while playing games when someone was streaming netflix or similar. Do you believe this would be caused by the double NAT?
If everything was connected to the 'inner' NAT, why would there be issues with SSH/Bounjour/etc.?
Message 3 of 31
Guru
Nat issues can cause multiple issues.
And the funny part is some routers will work fine on double nat's and others will cause nothing but issues. Its why we recommend getting that issue fixed first and then try the network out.
Message 4 of 31
schumaku
Guru
For general Internet surfing or most home office VPN double NAT isn't an issue. For gaming, ideally the console(s) ideally must have UPnP PMP control on the public IP address and the port forwarding. controlling two NAT routers in a line does make it very difficult, as the consoles and games use sophisticated NAT mapping and alternate ports - and the config would require manual duplication to the outer NAT router pot forwarding.
Be aware the QoS part can only work reliably if the router is under control of all traffic. Just the "inner" router can't do much (or anything) in this context.
These to items are the show-stoppers for double-NAT and more.
Message 5 of 31
camjones1708
I followed the steps in the link above to set the modem into passthrough mode (dynamic), added the nighthawk back in, and disabled QoS.
I am still unable ssh into my raspberry pi from my hardwired desktop nor my macbook through wireless. I confirmed the ip address on the raspberry pi. In addition, I cannot connect to my scanner same as before.
I'm unsure where else to check.
In addition, with this configuration I am getting much slower upload speeds. (70mbps compared to 600mbps+)
Message 6 of 31
camjones1708
I would like to add some info. I set up a port forward for 22 and was able to successfully SSH into the raspberry pi through the external IP but not the internal (10.0.0.x)
Message 7 of 31
Guru
the BGW320-500  is a pretty new device from what I can tell.
Have you tried leaving it in router mode and putting the netgear in access point mode?
Maybe the BGW320-500's passthrough mode is sketchy.
Message 8 of 31
camjones1708
Yeah, its a WiFi 6 device.
Wouldn't that ruin the point of using the nighthawk? The devices are directly next to each other. If external connections work but internal don't, it seems like the nighthawk is blocking certain ports under the covers.
I would like to add that this has not always been the case. It is relatively recently that I've not been able to connect to the printer/raspberry pi. And it used to be intermittent where a restart would resolve the issue.
Message 9 of 31
Guru
"ruin the point of it?"
Depends on what you're using it for. If you're using armor/qos/parental controls/ then sure it would.
But if you're just using it for the wifi/ethernet connection, access point mode isn't going to change those.
I don't know much about the att router you have whether its solid/sketchy but its worth trying. If its passthrough is sketchy, it can cause issues on the internal network.
Message 10 of 31
schumaku
Guru
Everything what was on the other "outer" network before must be connected to the Netgear router Wifi and LAN only - the only device on between the ATT device and Netgear router WAN/Internet port can be the network cable. All devices the might have to be reconfigured to fit the new set-up.
The Netgear router LAN and wireless (not the guest one) is fully L2 transparent, and Bonjour or UPnP SSDP discovery does work - permitting both devices are on the same network and on the same subnet, also the communication works.
@plemans that's why...:
My setup is the Nighthawk R7960P .... My reasoning for this is for QOS enabled on the nighthawk so I can game while others stream in the house.
8-)
Message 11 of 31
camjones1708
When switching from the netgear to the AT&T I unplugged the netgear entirely and then tested connectivity for the devices. The WiFi networks are the same so the devices will switch between as I switch the devices. When switching back to the netgear router, I am switching the AT&T device to passthrough mode and turn off wifi. I then have one cable from AT&T.LAN -> Netgear.WAN and everything is wired into the netgear or connected wirelessly.
I am not using any guest networks. They are on the same subnet mask 255.255.255.0. Both devices are pointing to the default gateway 10.0.0.1. And both can ping google.com. But I still cannot ssh while using the netgear.
Windows box IP: 10.0.0.10
Raspberry pi IP: 10.0.0.8
Message 12 of 31
antinode
Guru
> nor my macbook through wireless. [...]
   "unable" is not a useful problem description.  It does not say what
you did.  It does not say what happened when you did it.  As usual,
showing actual actions (commands) with their actual results (error
messages, LED indicators, ...) can be more helpful than vague
descriptions or interpretations.
   What, exactly, is connected to what, exactly?  What are the IP
addresses?
> [...] I confirmed the ip address on the raspberry pi. [...]
   That tells me what, exactly?
> [...] In addition, I cannot connect to my scanner same as before.
   Regarding "cannot", see "not a useful problem description [...]",
above.
> [...] I set up a port forward for 22 [...]
   Where?  What was the whole port-forwarding rule?
> [...] and was able to successfully SSH into the raspberry pi through
   From where?  How, exactly?  Regarding "not [able]", see ""not a
useful problem description [...]", above.  "10.0.0.x" is the address of
what, exactly?
   What _is_ "the point"?  Why, exactly, are you adding the R7960P?
> [...] If external connections work but internal don't, [...]
   Where, exactly, is "internal" when you have two routers?
Message 13 of 31
schumaku
Guru
Whatever could prohibit ssh on a flat network. Other services are reachable on the Pi?
@antinode you always bring up a smile on my face with your messages lol. Except of the "why" which was explaind several times above already.
Message 14 of 31
camjones1708
addresses?
From the attached devices table:
Gateway(netgear): 10.0.0.1
Windows 10 hardwire: 10.0.0.10
Raspberry Pi: 10.0.0.8
External IP: XXX.XXX.XXX.ABC
Internal example
CMD run from Windows 10:
ssh pi@10.0.0.8
Response
ssh: connect to host 10.0.0.8 port 22: Connection timed out
External example:
ssh pi@XXX.XXX.XXX.ABC
I am able to get in using my external IP.
above.
I am not doing anything active with the printer. To test connection, I open the Printers & Scanners tab and see if it is showing as connected or not. Additionally, I try and open the scanner on my mac. If I it shows disconnected on my Windows PC, the scanner has always failed to connect using the scanner utility. I am focused on the raspberry pi since I can run commands on it to identify any issues.
I had attached a screenshot but the reply is getting blocked. Created a custom service forwarding rule for
Made the following rules
External Start Port= External End Port = Internal Start Port = Internal End Port = 22.  Internal IP Address: 10.0.0.8
External Start Port= External End Port = Internal Start Port = Internal End Port = 8080.  Internal IP Address: 10.0.0.8
what, exactly?
SSH process was outlined above. For browser (explained below), I hit the URL:
10.0.0.8:8080
Then
XXX.XXX.XXX.ABC:8080
The internal IP address timed out while the external IP address served the webpage.
I wanted the QoS and administration control mostly. We just moved so when I bought it, it was also for additional wi-fi range. It is now more central where that is not as important. It seems like it would just be for whichever has better WiFi I would want to use.
Inside the netgears subnet while the AT&T is set to passthrough.
I apologize if I missed questions, the formatting is getting hard to follow as the replies continue to grow.
To answer the other question.
I set up a simple python server on the raspberry pi to confirm that it was or wasn't just SSH.
python -m http.server 8080
I am able to access that while using the IP: XXX.XXX.XXX.ABC:8080 through chrome. I am unable to access while using 10.0.0.8:8080. Same as SSH.
SSH does not require internet, I should be able to ssh inside the netgears network even without internet access. I can test that if that would provide any info.
Message 15 of 31
camjones1708
Attempting to include screenshots.
Ip Table.PNGPortForwardingConfig.PNGPrinter Not connected.PNGRaspi IP Address.PNG
Message 16 of 31
schumaku
Guru
Let me guess (screenshots will become visible once a moderator approved): ping the pi on its IP does not work on the LAN either?
Router LAN IP however works from the same computer?
Message 17 of 31
camjones1708
ping 10.0.0.8
Reply from 10.0.0.10: Destination host unreachable.
Your assumption is correct. Is it usual that the self IP will be listed above here? That is the IP of the machine I am pinging from.
If I port forward port 7:
ping XXX.XXX.XXX.ABC
It returns quickly.
I can also ping the gateway.
Message 18 of 31
antinode
Guru
> Whatever could prohibit ssh on a flat network[?] [...]
   That's my question.  You don't need the router for that, only a
working network switch/hub.  I suspect that we're missing some critical
details.  (Or you've found Netgear's worst firmware ever.)
> SSH does not require internet, [...]
   Neither does HTTP.
> [...] I should be able to ssh inside the netgears network even without
   Unless you have some seriously strange routing, the presence of a
router should not affect local traffic.
> From the attached devices table: [...]
   What is the address of its WAN/Internet interface?  (ADVANCED >
ADVANCED Home : Internet Port)
   That's the only active interface on the Windows system?  (Other IP
details?)
   That's the only active interface on the R-Pi?  Which interface?
(Which R-Pi model?)
   That was worthless.  If you're worried about revealing secrets, then
the top half of the address, "a.b" out of "a.b.c.d", would satisfy most
of my curiosity.  Or, plug that address into the form at:
https://whois.arin.net/ , and see if it is a public or private address.
> ssh pi@10.0.0.8
   Same command from the R-Pi itself?
   I can't (yet) see your pictures.  In-line images must be approved
by a moderator before others can see them.  The time required varies.
Attachments have no such limitation.  Of course, attachments have their
own one-per-message limitation.
Message 19 of 31
camjones1708
I agree, I am probably missing something here. I took A+ many years ago, but most of it is just a faint memory at this point.
I did downgrade the firmware thinking the latest upgrade may have been the issue. That did not resolve anything.
   Neither does HTTP.
76.202.X.X
details?)
Correct, Wifi is disabled.
(Which R-Pi model?)
WLAN0, R-Pi 3b v1.2
Included above.
> ssh pi@10.0.0.8
The pi can connect to itself at 127.0.0.1 and 10.0.0.8.
Let me know if there is anything specific that would be worth screenshotting. The screenshots I included were all just supplemental.
Message 20 of 31
antinode
Guru
   That much, at least, makes sense.
   Those are address reservations.  Are the devices (interfaces)
actually at those addresses?  ("ifconfig", "ipconfig", as appropriate?)
> [...] I am probably missing something here. [...]
   Perhaps everyone is.  I'd be tempted to shut everything down,
configure a minimal set of LAN devices (freshly reset router, R-Pi,
Windows system), and see if I could get the basic local stuff to work as
expected.  No exotic routes on anything, no address reservations, no
Internet connection, just the basics.  Then, if that works, start
complicating things slowly, stepwise.  Quit when it stops making sense.
Message 21 of 31
camjones1708
Yes, those are the device IP's as well.
I will try and get through that process tomorrow and see if it sheds any light on the scenario.
Message 22 of 31
camjones1708
After resetting the configuration, I am able to SSH and connecting to the printer. The only weird thing is that IP Allocation does not seem to be working anymore. I suppose that's not the end of the world though.
Also noticing the naming of the devices is being weird as well.
Message 23 of 31
camjones1708
Picture of IP Allocation Table
Message 24 of 31
camjones1708
I just noticed that after adding the static IP Allocation for those two devices, it seems that there are multiple assigned the same IP? In addition, I can no longer SSH. Does that make sense? (I restarted the router after adding in those two rules).
Message 25 of 31
Discussion stats
  • 30 replies
  • 3315 views
  • 2 kudos
  • 4 in conversation
Announcements
Orbi WiFi 7
