- Subscribe to RSS Feed
- Mark Topic as New
- Mark Topic as Read
- Bookmark
- Subscribe
- Printer Friendly Page
No update action. There is no IP address on the Internet port. - ORBI
- Mark as New
- Bookmark
- Subscribe
- Permalink
I had a power outage in Texas this last week and internet was down a while. When it came up it changed the IP address and my no-ip dynamic dns did not work. I have looked on line and looks like Netgear has this issue a lot and no resolution. I am hoping that is not the case. Does anyone have a solution? Thanks so much.
Router Firmware Version
V2.7.2.102
- Mark as New
- Bookmark
- Subscribe
- Permalink
Re: No update action. There is no IP address on the Internet port. - ORBI
> Model: RBR50|Orbi AC3000 Tri-band WiFi Router
Connected to what? Some kind of modem, or what?
> [...] When it came up it changed the IP address [...]
"it"? Which "the IP address"? "changed" from what to what?
Not really unexpected, is it? Otherwise, why use "_Dynamic_ DNS"?
> [...] and my no-ip dynamic dns did not work. [...]
"did not work" is not a useful problem description. It does not say
what you did. It does not say what happened when you did it. As usual,
showing actual actions (commands) with their actual results (error
messages, LED indicators, ...) can be more helpful than vague
descriptions or interpretations.
> I have looked on line [...]
"on line" is a very big place. Thanks for the helpful links.
Some message which you got from something or other when you did
something or other? Or what?
- Mark as New
- Bookmark
- Subscribe
- Permalink
It is connected to a Suddenlink Modem that assigns it a DHCP IP address. This was the first time it has changed since I have used their services in 3 years.
When my modem and Orbi powered back up, the modem changed it's DHCP addressigned assigned to the router. It was 47.221.225.x and now it is 47.221.245.x. I manually was able to change it on no-ip.com to match the new IP assigned to it.
When I check the status page on my Orbi Dynamic-DNS it gives me the error:
Advanced--> Advaned Setup-->Dynamic DNS--> (I'm using www.No-IP.com and logged in correctly)-->Show Status
I googled the error message: "No update action. There is no IP address on the Internet port." I reviewed the only netgear result below:
I also reviewed the other results that were from noip.com.
This was the exact message I received and I also googled it. Upon my research, it seems like Netgear has done nothign to resolve it. I would appreciate any assistance @antinode
- Mark as New
- Bookmark
- Subscribe
- Permalink
> [...] a Suddenlink Modem [...]
Not a very detailed description of that device, but if the router's
WAN/Internet interface is getting a public IP address, then that may be
all that we need to know.
> [...] This was the first time it has changed since I have used their
How many such storms have you seen over that time?
> When I check the status page [...]
Ok. Clearly, if the router (WAN/Internet interface) _does_ have a
good IP address, then a complaint like "There is no IP address on the
Internet port" would suggest defective firmware.
> V2.7.2.102
I see V2.7.2.104, but I wouldn't bet on its helpfulness.
Other than the usual last resort (settings reset, manual
reconfiguration), I have no suggestions. (I have a real DNS name, so I
don't deal much with DDNS.)
> [...] it seems like Netgear has done nothign to resolve it. [...]
That's the impression I got. An actual support case might get more
action than complaints here, however.
> [...] I would appreciate any assistance [...]
Sorry to disappoint.
User | Count |
4 | |
4 | |
2 | |
1 | |
1 |
• Introducing NETGEAR WiFi 7 Orbi 770 Series and Nighthawk RS300
