Reply
Topic Options
- Subscribe to RSS Feed
- Mark Topic as New
- Mark Topic as Read
- Bookmark
- Subscribe
- Printer Friendly Page
Online LED wont light up
- Mark as New
- Bookmark
- Subscribe
- Permalink
2021-08-26
12:03 PM
2021-08-26
12:03 PM
Hi, I’m using an AC1200 WiFi Cable Modem Router, Model C6220.
I’m pretty sure I have ISP, and I have all the required cables connected to power.
(Power adapter connected, Coaxial cable connected, and Ethernet cable connecting the modem router and the wall(?))
On the setup manual, it says I have to wait up to 10 minutes for the Online LED to light up after turning the power on.
However, the LED shows no sign of lighting up. The only LED lights I see are the power, ethernet, and downstream(although its blinking).
I don’t see my Wifi network name (SSID) on the network list on both my laptop and phone, so obviously, no connection, no wifi.
What should I do? please help
Model: C6220|DOCSIS 3.0 High Speed WiFi Cable Modem Router
Message 1 of 2
- Mark as New
- Bookmark
- Subscribe
- Permalink
2021-08-27
08:12 AM
2021-08-27
08:12 AM
Re: Online LED wont light up
You are "pretty sure" you have the ISP? Doesn't sound encouraging.
Perhaps this is a clue:
According to the manual that says "The unit is scanning for a downstream channel."
Support | NETGEAR
What does your ISP say about your service? Have you talked to them?
Your modem.router won't get very far if they haven't set up your service.
You might get more help, and find earlier questions and answers specific to your device, in the appropriate section for your hardware. That's probably here:
Cable Modems & Routers
Message 2 of 2
Announcements
